 - 31 Mar 2024
 - UK
Hi All, New here. So i recently upgraded to EE 1.6gbps, the EE SMart hub only has 1gbps lan ports, so i bought an ASUS GT-AX11000 Pro router, which has 10gbp LAN port, and 2.5gb WAN, then i connected the 10gb port to a BroTrends 2.5gb 8 port switch. Previously had all 1GB network gear. 1 of the PC's connected to the 8 port 2.5gb BroTrends switch is having regular micro drop outs, its not very noticeable as it drops and reconnects instantly, the PC is a relatively new build with MSI MAG Z790 Tomahawk board, 48gb ddr5 i5 14700k etc etc.. it has 2.5gb LAN port. I went round the houses for 2 weeks! I've never had a switch do this. Not knowing or thinking a brand new switch could do this, i bought a PCI NIC for the PC that was dropping out, still got the drop outs, tried different ports on the same BroTrends switch, still drop outs, bought new CAT 7 cables for everything connected to it, still gettting the drop outs, even bought a new motherboard, STILL DROP OUTS, then i thought, right, let me swap back to my old 1gb 8 port switch (TPLINK), drop outs stopped! dont know why i didnt do this sooner! but the thing that wasn't pointing to the switch was, none of the other devices connected to the switch were dropping out! Is this a faulty switch??
 My advice still stands. Also that no connection image denotes wifi to me rather than wired, but who knows what UI standards Windows does at this point. Also no mention of NBASE-T support in specs for the 10Gb port, I would be amazed if it didn't support it given the 2.5Gb WAN, but you never know.
