5 Apr 2024 at 18:14 #1 bitfenix bitfenix Associate Joined 22 Jun 2018 Posts 170 Hi Im on windows 11 home downloaded all windows updates but wont open now, Is there a fix? David
5 Apr 2024 at 19:33 #2 Tetras Tetras Man of Honour Joined 22 Jun 2006 Posts 17,530 I assume you have restarted the computer?
5 Apr 2024 at 19:36 #3 bitfenix bitfenix Associate OP Joined 22 Jun 2018 Posts 170 Yes I have restarted computer and turned off and on again. Could it be spyware or virus?
5 Apr 2024 at 20:27 #4 Tetras Tetras Man of Honour Joined 22 Jun 2006 Posts 17,530 bitfenix said: Yes I have restarted computer and turned off and on again. Could it be spyware or virus? Click to expand... If you google it, there are quite a lot of suggestions about how to fix it and most of them aren't related to a virus.
6 Apr 2024 at 16:28 #5 bitfenix bitfenix Associate OP Joined 22 Jun 2018 Posts 170 Thanks Tetras, been on google watching loads of youtube videos on solutions but none work. Don't want to clean install just to fix it Anyone help with same problem? SORRY problem solved played about in settings and its back now online. Last edited: 6 Apr 2024
23 Nov 2024 at 18:10 #6 bitfenix bitfenix Associate OP Joined 22 Jun 2018 Posts 170 HI Every time microsoft make a update on windows update it fixes the windows security on Windows 11 Home, then a day later goes broke again. Can anyone help? David
24 Nov 2024 at 00:22 #7 theforce theforce Associate Joined 5 Jan 2005 Posts 2,239 Location Cyprus "Not everything needs to work" Microsoft
