Yea basically it's the same.
As you go higher up the difficulty levels that gives your variation because not only are there more objectives and stuff to find, but the gameplay changes because you can't really just run around shooting everything like you can on the earlier difficulty, and the use of the right strategems for the right scenario comes into play etc
But yes, you basically have to appreciate it for what it is, which is why I think it doesn't deserve some of the hype it's getting, it's certainly not game of the year, but...... If you appreciate it for what it is, it quite a fun a chill game to pick up and play for an hour or so, every now and then, I enjoy it anyway.
I'd get the tin foil helmet first mate.Well I finally became a Citizen!
I wouldn't install their rootkit virus on my PC, so I bought an external USB SSD and HD2 has its own copy of Windows and nprotect can do whatever it wants as I will do nothing else at all on that copy of Windows!
So... what should I unlock with my medals?
The dynamic ADS is such a great option.Turn ... I think its called "dynamic mode aiming" on in the settings so you can over shoulder and ADS aim. Rebind the strategem keys to Arrow Keys and turn the radar button to Hold-TAB
Did they seriously make it so you can't play against automatons at all right now? (obviously will be a reset at some point) that is a pretty **** thing to do, even as someone who doesn't find them engaging at all and rarely does bot missions.
EDIT: I can't even join anyone so far tonight just endless attempts then nothing... repeat![]()
and can't complete operations myself.They seriously need to fix the crashing though
I think they take time to come through.Did anyone get their medals after the Major order finished?
I logged in yesterday (Didn't play any missions as just checking some settings) and received nothing
I do prefer the bugs over the automations.I think they take time to come through.
Well after the last 2 weeks of fighting bots I'm looking forward to the bugs, I've only fought them twice so far...
Yeah, if you are hit you need to stim otherwise your a dead man lolOh man the Hulk flamers are insane. They insta kill you at ten miles if a little whisp of flame tickles your cape
