- 18 Oct 2002
- Aranyaprathet, Thailand
I want to use 6 Phanteks D30 all regular direction. Three on the front pushing through a rad, two in the roof pushing through a rad and one on the back.
So, is it possible to connect all six to a single controller or will it need two controllers?
Can the rear single fan and the top two be daisy-chained with the included cables?
, I’ve always limited to 6 fans per ARGB port. Usually you should’ve 2 ARGB ports with most motherboards nowadays, otherwise a cheap £10 powered hub should be a safe investment.
