Deleted User 298457
Deleted User 298457
I'll DM you my deets to ping it over <3£167 over the year makes so little difference.
We're putting in an extra £200 per month
but for £167 over the year makes so little difference.
There is the "safety" net of savings being accessible should something go really wrong.I don't think I'd bother with maxing savings vs mortgage overpayment when the difference is 4.57% to 5% ish tbh, whilst yes it's better, it does add some extra work
In my case though, mortgage is 1%, and savings is 5%, this is a no-brainer and is potentially a lot more than £167, so I am maxing the savings.
But as we discussed many times, savings can be a lot more flexible in how you deploy them, mortgage overpayment you can't get back easily and use for anything else.
32 years, ‘eek’, at least the balance is t too high.
Technically the correct answer is to maximise the best interest rates you can get on either saving or finance. As soon as the highest APR you are paying drops below the savings APR (after tax where applicable), you could switch to savings.
Personally, we save and pay down the mortgage. The temptation to spend the savings when they mature on something other than the mortgage (which is tomorrow’s problem) is high. Paying it off right away guarantees it’s actually paid down early.
If the difference was small, I wouldn’t bother with the savings part either.
Yes, but it's all based on what the lender thinks will happen with interest rates during the course of the term (which in turn is likely to be based on what the money markets think).Did tracker rates not used to be less than fixed in the past? I might need a slap with a wet kipper...it is Monday morning.
Pay the mortgage with that and then start saving againWe've got other savings for a safety net.
That's one of my reasons for just paying it straight off - we won't spend it.
Basically, you pay a premium for a fixed rate if they expect rates to go up. If they expect rates to come down, then you pay a premium for a tracker (incidentally, this is also why you occasionally get fixed rates that are lower even than base rate, because the expectation is that borrowing will get a lot cheaper in future).
If you time it right in terms of predicting the direction of rates and grabbing products before they are removed/adjusted, trackers can be a great deal. I took out a zero fee +0.59% lifetime tracker about 16 years ago (I feel old writing that out!), rates then fell by about 5% and paid off the mortgage before rates rose again.
Pics of wife on holiday so I can do the maths?A friend overpays his mortgage knowing he'd be better off financially putting it into a savings account, as soon as the value in the savings account got anywhere near 'holiday in the sun' levels his wife would be bending his ear to spend it.
You’ll be taxed on savings tooWe've started overpaying our mortgage today. It's at about £290k with 32 years left at 4.52%. We're putting in an extra £200 per month, which should bring the end of it 7 years closer!
I know we could get 5% in a savings account, but for £167 over the year makes so little difference.
I always find it a bit ironic that we have these detailed threads about optimising finances in terms of mortgages/savings etc but then people are worried about savings burning a hole in their pocket! I mean, to me it's all interconnected as part of the plan, you put money aside in savings categorised for your future mortgage payments and don't spend it, it's a non-issue, so if people are worried about that it makes me wonder how they are so careful in other areas. People might say "aha, but what if something unexpected comes up you need the money for young man, your nerdy saving will fall flat on its face and then you've spent the mortgage money amirite???" but surely that's an even bigger problem if the money has already gone into the mortgage as you'd have less liquidity to deal with the unexpected short term cost before getting things back on track? I just don't get it, it's all about a timing offset that gives you both more money at the end of it and also more short-term flexibility by having cash not yet sunk into the mortgage prematurely.That's one of my reasons for just paying it straight off - we won't spend it.
It is, but if you put it in a calculator then you basically gain nothing over 7 years
By nothing, you mean £347.31 ?
That's saving £200 a month at 5% savings rates vs paying off mortgage each month by £200 using your mortgage rate of 4.52% over a 7 year period.
EDIT: Assumptions made in my example was £1500 a month payment.
