Bit of weird thread this, maybe in part it's just seeking motivation to get off my backside and sort out a problem, but here goes
Background
Currently, I have a 5900x setup in an old (>20 years) case. It has a very big/heavy air cooler, Alpenhof Olmyp which I bought second hand and has a slightly dodgy bracket, meaning it isn't operating at full efficiency, it also sags a bit (which I've partially rectified with a heath robinson solution, don't ask... but temps are better when I have this applied). For an air cooler, in theory it should be pretty good, it is rated for 340W TDP, massive chunky heatsink sticking out with two giant fans bigger than my case fans etc (I deliberately wanted a high end air cooler to try and stretch the 5900x a bit), but obviously this is compromised the way I have it setup.
Issue
Temps run pretty hot, it has a 6900XT right underneath pumping heat up into it, and my son now has a PC in my office too so ambient temps are only going to increase going into summer. Under load using my tweaked PBO2 settings etc it hits 90C which I understand is the point it will invoke thermal throttling(?).
In short, whilst the system is generally stable it's not great and I feel I could get higher sustained clocks with better cooling.
Options moving forward
Background
Issue
- Reseating the cooler: As I say I got it second hand with a dodgy bracket and I don't think reseating the cooler is a realistic option, I'm not great at this stuff and will probably just make it worse, it's an absolute beast
- Replace with a 280mm AIO cooler I bought a year or two back but haven't opened, this would be in an existing case. The complication here is I don't have a big modern case, my decent sized cases are pretty oldschool with the PSU at the top, I think mounting the AOI radiator will be hard as there's like 5.25" bays in the way etc. I've never used an AIO before so don't really want to be facing adding complications.
- Replace with a Hyper H412r cooler. I have one of these still in the box I bought cheap for another project, I think it's only 100W TDP though so not really suitable for a 5900X. Probably a waste of time.
- Buy a new case and setup the AIO cooler. My head says this is the right option, however I don't really want to invest in a new case (wife already not happy at the amount of towers I have laying around) plus have the hassle of tearing everything down and rebuilding it. Although option 2 would involve a lot of faffing about in the case to get things to fit anyway, so no worse than that.
- Buy a new air cooler, better than the H412r. Not keen on this option, it would probably be the easiest in terms of faff just swapping out the cooler with everything else in place, but feels like a waste given I have an AIO sat in the box.
- Do nothing. As mentioned the system is running OK, I could just leave it setup and then in the future when I do an upgrade, sort out the problem at that point
