Thermaltake Tower 200 can take upto 380mm GPU and advertise for a 4090
Similar to the TUF 4080’s dimensions.
Gear seekers, on YouTube, used the Coolermaster NR200P V2 for the massive Asus.
Matx case and option?only problem with this is my GPU is 5mm thicker and the one in the video is to the limits
no point downsizing to Matx the foot print of my case is not bit it just tallMatx case and option?
Take a look at the meshlious is says GPU compatability something about baffle so it mite work for you.no point downsizing to Matx the foot print of my case is not bit it just tall
				Did you take a look at the meshlious?This is like when someone says where the best place to go for a good steak and a vegan pops up.
Your points are all valid but herrr…
I did but that was the GPU is mounted would mine fit length wise.Did you take a look at the meshlious?
So im thinking of moving my system into a ITX case but i have a massive GPU
Card size L=342 W=153 H=70.6 mm
Yes I believe so if the baffle thing is taken into consideration.I did but that was the GPU is mounted would mine fit length wise.
