I’m not confused by sync speed.
I’m using an ASUS ax86U I know how much they are disliked on here but works fine for me.
What speed is your internet connection?
The iPhone 15 Pro supports 160MHz on WiFi 6. Sync speed is 2400.Strange result because the iPhone 15 Pro only supports 2x2 (80MHz) on 5GHz AX so PHY (simplex) data rates of 1200Mbps (600-ish Mbps actual maximum transfer speed). Could you be on Wifi6E and not know it?
My router literally doesn’t support 6E, it has no 6GHz radio, it’s physically impossible for me to be on 6E.
RT-AX86U Dual Band WiFi 6 Gaming Router, - Specifications
PS5 Compatible, Mobile Game Mode, Lifetime Free Internet Security, Mesh WiFi support, 2.5G Port*, Gaming Port, Adaptive OoS, Port Forwardingwww.asus.com
Doubt all you want, but unless speed test is giving me many, many errored results then I am indeed getting the speeds I should be.
Anyone with decent hardware can get Gb speeds over WiFi.He is hitting the limits of WIFI.
It's a limitation of WiFi that's holding back the speed, the limitation being most likely wifis susceptibility to environmental factors.
Even sat next to my AP like touching it I don't get the theoretical max speed. Sync speed might look impressive but that's not the same as actual throughput.
Edit: WJA96 beat me to it.
How stable is it with EE? I'm with Aquiss at the moment but contract ending in a month or soFinally got rid of Virgin and moved to EE 1.6
The latency is so much better.
Compared to Virgin, very stable. I use my own router though - with 2.5gb WAN and LAN.How stable is it with EE? I'm with Aquiss at the moment but contract ending in a month or so
Yeah why is the UK SOOOO far behind the rest of the world with uploads?It’s just such a shame that there’s no bigger upload lift on the 1.6 package.
Do ISP's think all us UK folk just host servers all day?
