 - 10 Nov 2012
 - Down the road from Diddly Squat Farm
Has anyone ever seen an increase in efficiency with a remap? I get the feeling it's more theoretical than practical. My experience over two cars is they make the car more thirsty.
Considering remapping as apparently it helps with fuel economy.
This is what you need, not some from stock map just bunged on and hope for the best.I've had a remap for 5 years, it's driven daily and the occasional track day, and so far so good. It's a little mx5 and I got a switchable Ecutek map with race rom features.
Economy has indeed improved:
Stock mpg: high 20s day to day and low 30s on a long run.
Remap: low 30s day to day and mid to high 30s on a run.
I got 15mpg from 4 laps of the Nurburgring
The power increase was modest, 158bhp to 185ish, but the drivability improvement over the stock map is huge. The tuning guy did lots of small adjustments between Dyno runs to get it how he wanted it.
From memory he did the following:
Loaded in his best saved map for my engine as a starting point.
Then in between Dyno runs he did:
Fuelling
Cams
Knock
Then he did another run and then did:
Knock
Cams
Fuelling
The above order might be wrong.
In addition to the above, he did the following:
Removed the factory 90% throttle restriction for first and second gear.
Ironed out a flat spot at 4000rpm.
Decreased the fuelling at idle by 25%.
At £570 it wasn't cheap, but IMO well worth it.
Why would you be driving quicker all the time? Does having a remap cause your speedo to stop working?It might technically, it won’t realistically. You’ll be driving quicker all the time, hence using more fuel.
Of course it's possible to gain efficiency (in the same way that it's possible to gain performance), by reducing the fairly wide tolerances that ECUs have a result of normally being designed for multiple markets (and the varying fuel quality, emissions standards, and environmental factors like target air temperatures and the like).Has anyone ever seen an increase in efficiency with a remap? I get the feeling it's more theoretical than practical.
				Why would you be driving quicker all the time? Does having a remap cause your speedo to stop working?![]()
LV insurance don't seem to mind remaps oddly and have been quite cheap for me.
I'm basically locked in to LV because every other insurer was £200-£300 more a year.
I did it on my Volvo went from 150 to 180hp and it's not a huge difference, a bit more power on the higher rpm, but it's marginal.
I got the official polestar map from Volvo as well, and the car has been fine for many years, I wouldn't go to a third party place, even though I'm sure most of them are perfectly fine.
But basically I wouldn't bother, I won't ever do it again on another car.
If they knew exactly where the car was going to end up, and what kind of customer was driving it then yes.Manufacturers, for years, have had a primary focus on fuel efficiency for selling cars. Do you not think that if it was a simple case of software tuning to increase efficiency, that they’d have done it?
