- 4 Jul 2006
Nice to know early if you got a gas leak as well if you see it going up and you are not using it.It's nice to see how much you are using on both electricity and gas though.
You'd smell it.Nice to know early if you got a gas leak as well if you see it going up and you are not using it.
It really is. I’ve saved hundreds of pounds since getting one along with Octopus Tracker.Still not sure, if smart meter is worth upgrading to.
If it was in the house sureYou'd smell it.
My new IHD started fully working over the weekend and is now showing all the data as normal, which also means the Geo app is updated live too, which is handy. Even better is that the old IHD now works again, so I can have one in my living room/kitchen and one in my office.They've been okay for me, after sending them a photo of the rear a couple of days ago it's showing connected to my meter now, though it isn't actually pulling any data about usage etc yet.
Unfortunately it seems to have disconnected my old IHD in the process.
They replace the meter and will provide an In-Home Display, but you can plug that in wherever you like (within range of the meter).My meter is from 2004 - soit's not smart, do they just upgrade the one I have - or install something else inside the house? - My meters are in the the usual grey box on an outside wall.
No. Why would you even want that to happen?
Why don’t you want a smart meter?Because I don't want a smart meter.
Pretty sure that this thread has been answered now, and it's just going around in a loop.
Some people like them, some don't, some just have an irrational dislike.
is that when we recommend Bacofoil as our preferred brand?
