We do that, but still need to run a knife under the hot tap for a few seconds just now. As the weather warms up the (first world) problem will go away.Salted butter, keep it on the counter in the kitchen. Sorted.
Never heard of a butter bell, off to google I goI’ve been using a butter bell for a while, not 100% sure how hygienic they are (change the water every few days) but you don’t keep it in the fridge
proof that lurpak is good - >
lurpak (no salt) is Lome, president prme is good too, at 20min out of fridge, and 20C - twice as spreadable as some alternatives.
if you are using a pat of butter a week, you don't leave it all out of the fridge, just decant what you need every couple of days into (Genx thing ?) butter dish
Currently have lurpak + Aldi + farmfoods butter (pats not spreads) on the go -
lurpak is always a lot softer and easier to spread despite cooler spring temperatures, and reserved for bread/toast,
but costs more, had frozen a lot of lurpak when they sold off the 250g's pre-shrinkflation to new normal 200g.
I have found that, as it's well into spring the butter has sofened a bit and can spread it on soft brown bread.
I have stopped having white bread toast as all versions of white bread now to me, taste like wet cardboard.
This week when shopping I put a malt loaf in basket as I haven't had one for years (Soreen I think) - it was like cutting a brick in half - so unless it was past it's eat by date they have now become uneatable. I used to love those soft squidgy covered in butter slices of malt loaf.
