It is alright, better than the stock coolers used to be.Also I wasn't sure if the cooler was good enough or not.
Would I need anything else to build this? Is that all good enough/compatible??
My basket at OcUK:
- 1 x AMD Ryzen 7 5700X3D Eight Core 4.1GHz (Socket AM4) Processor - Retail (SKU: PRO-AMD-01799) = £239.99
- 1 x Gigabyte GeForce RTX 4070 WindForce OC 12GB GDDR6X PCI-Express Graphics Card (SKU: GX-1G2-GI) = £509.99
- 1 x Team Group Vulcan Z T-Force 32GB (2x16GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Grey (SKU: MY-0AJ-TG) = £59.98
- 1 x Phanteks AMP 650W 80 Plus Gold Modular Power Supply (SKU: CA-09Q-PT) = £89.99
- 1 x WD Blue SN580 1TB SSD NVME M.2 2280 PCIe Gen4 Solid State Drive (SKU: STO-WDC-00540) = £64.99
- 1 x Asus Prime B760M-A WIFI D4 (LGA 1700) DDR4 Micro-ATX Motherboard (SKU: MB-6KG-AS) = £119.99
- 1 x Aerocool Dryft Mini v2 Micro-ATX Case (SKU: CAS-AER-00607) = £55.00
Total: £1,147.92 (includes delivery: £7.99)
In HUB's videos they generally recommend that you do not buy a 5700X3D/5800X3D unless you already own an AM4 motherboard and instead get a 7500F or 7600, so that you can take advantage of future CPU upgrades and DDR5.Would I need anything else to build this? Is that all good enough/compatible??
If it helps, then just to clarify a few things.That is way over the £700 I had in mind when I started with a 4060.
I'm gonna have to think a lot about it because even with a monitor £1.000 was already a lot to push this is out of my budget by a lot...
Amazing thank you! I'll have a look at it later.If it helps, then just to clarify a few things.
If you say to us "I want to play @ 1440p", especially if it involves VR, we're immediately going to think "DOUBLE THAT BUDGET!" because the truth is that 1440p gaming (especially VR gaming) is very demanding with modern games and we will very rarely make you a spec for just one or two games, because:
1. The PC won't last long when you decide to switch to the latest AAA racing game, or whatever.
and
2. The lack of utility in the build is something hard to justify when you're still spending a lot of money, relatively speaking to many other hobbies.
Sooo... that said, can you play at 1440p with a lower-end card like a 3060 12GB, 4060, or RX 6600? You absolutely can, many games (especially older ones) will run just fine and if you use FSR or DLSS you'll get by in many more.
How to know?
There's two ways: check benchmarks for those specific games or check YouTube videos with the kind of hardware you're thinking of, e.g. search for "F1 2020 RTX 3060 1440p".
Here's an example build closer to the budget:
My basket at OcUK:
- 1 x Intel Core i5-12400F 2.50GHz (Alder Lake) Socket LGA1700 Processor - Retail (SKU: CP-6AR-IN) = £124.99
- 1 x Team Group Vulcan Z T-Force 32GB (2x16GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Grey (SKU: MY-0AJ-TG) = £59.99
- 1 x Gigabyte GeForce RTX 3060 WindForce OC LHR 12GB GDDR6 PCI-Express Graphics Card (SKU: GX-1FH-GI) = £269.99
- 1 x B Grade Phanteks Eclipse P400 Air Midi Tower Case - Black (SKU: BG-06C-PT) = £39.91
Total: £781.84 (includes delivery: £11.98)
In this review, F1 2020 gets 126+ FPS at 1440p (max settings, no upscaling):
EVGA GeForce RTX 3060 XC Review
EVGA engineered a compact dual-slot design with the RTX 3060 XC that will fit all cases. Unlike all other RTX 3060 cards we've tested today, a metal backplate is included. EVGA's card ticks at a rated boost of 1852 MHz, and the cooler features the idle-fan-stop capability.www.techpowerup.com
In this review, F1 2022 gets 42 FPS average at 1440p (ultra settings, no upscaling). FYI: 4060 gets 52 FPS average, though there may be texture quality issues with only 8GB that aren't shown in the benchmark.
Nvidia Clown Themselves… Again! GeForce RTX 4060 Review
Antec Performance 1 FT: https://bit.ly/3oSWOM3Support us on Patreon: https://www.patreon.com/hardwareunboxedJoin us on Floatplane: https://www.floatplane.com...www.youtube.com
You'd need to look for AC specifically, since it is not present in those benchmarks, I just did a quick search:
Assetto Corsa Benchmark - Ultra Settings | RTX 3060 12GB | i7 12700K | 1440p
PC Specs:- Intel Core i7 12700K 3.6GHz- MSI MAG Z690 Tomahawk WiFi DDR4 Motherboard- G.Skill Ripjaws V 16GB (2 x 8GB) DDR4 3600MHz CL18 Memory- Samsung 980 M...www.youtube.com
I hope that helps with having some more context for your decision.
I'd recommend you have a good read up on reddit before you buy.quest 3
I guess next would be to get something like 4070 super? Is there anything in between that is worth having while keeping it cheap?I'd recommend you have a good read up on reddit before you buy.
From a quick look, there are a lot of users who say that a card like the 3060 or 4060 is very much borderline for playability, though there are also a fair number of users who say that they have one and it is fine for them, so I suppose it depends on your expectations and the requirements (..and especially the age, I assume) of the games.
So long as you're going into this with your eyes wide open about the compromises you might have to make and that it'll probably only be good enough for today's games, I suspect you'll get away with it.
I get that to be able to play properly I'd need to spend a bit more than I was expecting but I don't think I could afford it or my other half would allow me hahahah
This is much harder than expected hahahaNot when you need a Nvidia card I'm afraid, you might luck out on the second hand market with something like a 3080.
Not really, the 3060 12GB is a decent card, especially around £250.I guess next would be to get something like 4070 super? Is there anything in between that is worth having while keeping it cheap?
Worse than the 3060 12GB, so if that's barely enough for the Quest 3, then the 1660 Super definitely won't be enough.What about a 1660 super?
The 4060 Ti is barely any faster than the 3060 Ti (sometimes it is slower!) and the 8GB of memory is poor for 2024.
The 16GB version is more usable, but it costs way too much for the performance on offer and since they didn't increase the bus width with the memory, it is far less effective at higher resolutions than the 16GB of memory suggests it should be.
If the 3060 12GB is around £250 and the 4060 £300, then yes.Would you still choose 3060 over 4060?
