AMD Zen 5 rumours
29 Jan 2015
It went 1000, 2000, 3000, 5000, 7000, and next 9000 for desktop. APU's went 2000, 3000, 4000, 5000, 6000, 8000.
Zen 1 was 1000
Zen 2 was 3000
Zen 3 was 5000
Zen 4 is 7000
Zen 5 looks like 9000.
If the pattern holds Zen 6 will be 11000 or AMD will rehash the branding entirely.
The only reason 2000 was more than just APUs / OEM stuff was because AMD released Zen 1+ as an actual part but it was not a new Zen iteration so did not get the 3000 branding.
13 Jun 2012
yes, but there is a difference between NPU TOPS and total-system TOPS.
i.e. Hawkpoint
NPU = 16
CPU = ~3
GPU = ~20
so when i say i don't believe the WCCFTech article, it's because i don't believe strix point has just 25 TOPS from the NPU (half that of strix halo).
specifically - i believe that both products use the same XDNA2 NPU at similar clocks, and both will achieve ~45 TOPS from the NPU.
I think this is near enough confirmed now:
AMD Ryzen AI 9 HX 170 CPU. The APU features 12 cores & 24 threads based on the Zen 5-core architecture. The chip has a clock speed of up to 5.1 GHz, up to 77 AI TOPS (45 XDNA TOPS), and 36 MB of cache.
Caporegime
17 Mar 2012
ARC-L1, Stanton System
13 Jun 2012
i've seen it elsewhere that the breakdown is 16TOPS(cpu)/16TOPS(gpu)/42TOPS(npu), be interesting to see how that compares to Hawkpoint...?
15 Oct 2003
Chengdu
Right now, are there any desktop applications utilising the AI parts of these chips?
I know Windows 11 will soon, but having a dedicated AI section of a CPU just to harvest data and send back to Microsoft isn't really that appealing to me.
At the moment, it's feeling like just a way to slap an "AI" badge on. Which makes sense, as that's all you need at the moment. Just say AI and money flows.
OP
6 Feb 2019
As far as I know there isn't really anything using those cores that could be considered "real world". On phones AI cores are used heavily for photo and video processing, so maybe on PC Photoshop will use those cores
15 Oct 2003
Chengdu
I guess it's a "build it and they will come" type thing, but I wonder if by the time we see proper apps using it, these initial NPU offerings might be a bit rubbish.
1 Feb 2006
I would prefer AMD used the silicon for something useful (CPU cores, quad channel RAM, Extra PCIe lanes, better iGPU…), basically anything other than AI. Think I will skip the 9x chips, hopefully the AI BS will be over for the Zen 6/7.
Caporegime
17 Mar 2012
26 Aug 2004
South Wales
Lenovo employee says Zen5 has 10% higher IPC than Zen4
I thought someone said "Can't wait to show you Zen 5" like a year or 2 back? Was it Jim Keller? 10% is pretty disappointing, putting it very mildly. I know there's clock speed on top but a small bit isn't going to make much difference.
28 May 2007
who cares about IPC speculations
the elephant is in another room: "In addition, Win10 enthusiasts please note that starting from Strix Point, AMD will not provide Win10 drivers"
grrrr
I don’t think that’s going to be much of a problem unless you buy a laptop in kit form.
11 Dec 2016
Oxford
I bet same will apply to Zen 5 desktop
I don't see any benefit in Win11 and the only "reason" to upgrade is being forced like this by made up requirements
oh joy, time to study ways to make win11 reasonable (no MS account, replace start menu, remove ads, reduce background bloat, whatever the story about Virtualization-Based Security)
