Caporegime
- 18 Sep 2009
- Dormanstown.
They'll get rid of VAR and then first week there will be an incident VAR would have prevented and we'll be back to square one.
I think if you draw a line, and maybe see if any distant clouds are over it, it may not be as clear as you think. Though could be wrong, better ask another assistant, then get confused.I think it's clear as day
And no you can't reference one game in 2009!
VAR decisions seem to take into account the refs feelings as #1 priorityOutgoing Liverpool manager Jurgen Klopp says he would vote to scrap video assistant referees (VAR) as officials "are not able to use the technology properly".
I have an idea, kinda similar what Lineker said on the podcast.
Each teams gets say 1 “review claim” per half.
Referee makes decision on the pitch.
If a team disagree with a decision, he can request the Ref to go to the monitor. The team (Captain only) has to tell the ref what the claim is for. From “there was handball”, “I was clipped in the ankle” etc
The ref goes to monitor and check for the claim.
There is NO VAR upstairs.
Ref then makes decision.
(For offside decisions then it’s the automated system)
If there is no VAR, does every goal get checked? So lets say team A scores from a foul. Team B goes yeh that’s a foul - checked correct and it’s chopped of. A while later in the same half Team A player dives in the box and it’s given by the ref.
Can Team B check it because they call their first call right?
Or similarly they then score another goal which has someone fouling a defender its clear as day it’s a foul but the ref just can’t see it - does that goal get checked or is it just tough ****?
Seems like as it is now, the Ref will only see what VAR wants him/her to see.If a team disagree with a decision, he can request the Ref to go to the monitor. The team (Captain only) has to tell the ref what the claim is for. From “there was handball”, “I was clipped in the ankle” etc
Who communicates that to the captain if they’ve not seen anything themselves either?The team (Captain only) has to tell the ref what the claim is for
How long does all that take? And how does the captain know it’s not just someone crying foul?You mean the other players who’s seen handball or been fouled wouldn’t shout “FOUL REF!” Or “HANDBALL!” And they will shut up and keep quiet?
Then the captain would just go to the ref and relay that, all it takes is asking his team mates “you sure?”
I get what you’re saying, I just don’t think it’d work.I don’t know, it’s just an idea. I am thinking that he has 1 claim per half, so he has to be confident and use that wisely if he wants to get the ref to review it on screen. He will just have to look at his teammates and ask “you definitely saw it yeah?”
“Yes Stevie, get the ref to check it!”
Only one claim per half? 30 seconds after he’s used that shout there could be a worse ‘miss’ by the ref. Far better and likely easier to just make the current system work properly I’d have thought.
