No, they are just plug and play if "blind deployment" used. Just clips to the frame with sprung steel, make sure you clip them to the top of the panels not upside down to stop water ingress.Question to the Solar Minds - Tigo optimisers, is there anything else i need other than those. i dont need to monitor them, just want them to help the shaded panels in the morning and evening
Thanks
i will screw them underneath the panels to the timber ground mount, so i dont need to remove the panels to fit themNo, they are just plug and play if "blind deployment" used. Just clips to the frame with sprung steel, make sure you clip them to the top of the panels not upside down to stop water ingress.
That's fine, although they're supposedly watertight, the recommendation is still keep the tails end (connectors) lower than the top.i will screw them underneath the panels to the timber ground mount, so i dont need to remove the panels to fit them
yup thats not an issue.....time to get buying lolThat's fine, although they're supposedly watertight, the recommendation is still keep the tails end (connectors) lower than the top.
I'm currently generating 124w...........French weather again!Could be another good day on the cards……
those pesky french....I'm currently generating 124w...........French weather again!
£32.39 including VAT per optimiser from here:yup thats not an issue.....time to get buying lol
Same, 39 No. Also TAP & CCA as well for monitoring.They are what I've got on my panels![]()
I like it for the performance of each panel and the potential to identify any problem panels in the future.Is the monitoring good?
im going to get them for when i move the panels to new shed roof.....late summer/autumn. will apply for G99 at the same time then too, as i can fit more panels then and bigger inverterI like it for the performance of each panel and the potential to identify any problem panels in the future.
