- 27 Jul 2005
- The Orion Spur
hi there, just require a bit of advice building an AMD system, I've had intel since Athlon 64 days,
Currently I have
Mobo: ROG STRIX X670E-A
Now ram is next, I thought I'd grab this,
www.overclockers.co.uk
This ram is on the compatibility list for this motherboard, but then a customer review says the following,
"DOES NOT RUN AT 6000MHZ ON AMD; Context: To run the ram at advertised speeds, you have to enable EXPO, otherwise you'll run at 4700mhz, NOT 6000mhz, if you enable EXPO, it'll cause random crashes, issues, and memtest will come back with errors, (As it requires 1.35v, and current AMD bios limitation is 1.3v) So to run the ram in expo, you'll need to run it at 5400mhz, as currently, there is no way for this ram to reach 6000mhz on Ryzen systems. According overclockers support, that is normal, and not sure if it was confusion or what, but it felt like they assumed enabling EXPO = Manual RAM OC. TLDR: ACTUAL SPECS OF THIS RAM IF NOT ENABLING EXPO 4700mhz base, and 5400mhz EXPO low voltage option (As the 6000mhz, no longer works) Performance loss is marginal, only around 3% - 9% so do with this information what you please."
Can someone recommend 32GB RAM that will work with my motherboard 100% with expo enabled?
Currently I have
Kingston FURY Beast EXPO 32GB (2x16GB) DDR5 PC5-48000C36 6000MHz Dual Channel Kit (KF560C36BBEK2-32)
Order Kingston FURY Beast EXPO 32GB (2x16GB) DDR5 PC5-48000C36 6000MHz Dual Channel Kit (KF560C36BBEK2-32) now online and benefit from fast delivery.
