- 4 Feb 2011
After experiencing a QN900D which supports 8K 60hz, and seeing the ludicrous level of sharpness from a 65" TV, I'm now all in on the 8K rabbit hole.
The only other TV I've seen at that size or larger is the LG OLED77Z39LA 77 inch OLED Evo 8K (I don't know if this supports 120hz but if it does I'd buy one) I'd rather not have to buy one and then find out.
Why aren't there any monitors/tv's I can see even on the horizon for sale in this 8K arena, ideally I'd take 8K 120hz if I had an option, but I don't want to be buying 8-5 year old tech just for the resolution and still to be stuck at 60hz.
I may have to consider a QN900B/C as the 240hz isn't needed for gaming in my use case. I'd rather have 8K 120hz for gaming (single player games) and just stick with my 360hz 1440p for any other type of games, but looks like 60hz is the limit at the moment.
I should also clarify I have already tried the G95NC as well but the matte screen isn't for me, otherwise I would have happily stuck with it as it was great for gaming but not for me in desktop usage and it supports 240hz... and that's 7860x2160 instead of 8K which is 7860x4320
Looks like China is the only place to get access to what I want, but it's a pain navigating their storefronts, there must be an easier way I'm unaware of to get access to some China only products? or at least be able to find them if nothing else.
I get it's super niche for now, but we're on the cusp of a 5090 and what better way to push and justify such a purchase then going a step up in resolution as well.
If anyone else is having similar thoughts for the near future, I'd like to know what you've settled on for now, or what you're waiting for in the near future.
Apologies for the awful layout of my post and my ramblings
the alternative is to upscale to 8K or something close with DSR I believe? if you have the ability to turn DSC off on a compatible display anyway, or so I've read.
