Some updated pics of the beast and her lazy eye! That's on the list of things to fix...
She's so super clean. Odds and ends to do to her, which is this list up next:
- Engine oil & oil element replacement
- WAKOS PRO-S10W-40 engine oil Pro Stage
- Filter assembly AY100-KE001
- Transmission oil replacement
- WAKOS RG90 gear oil RG90
- Differential oil replacement
- WAKOS RG6140LSD gear oil 140
- LLC (Long Life Coolant) replacement
- LLC-G Coolant Green
- Brake fluid and clutch fluid replacement
- BF-4 Brake fluid DOT-4
- Battery replacement
- PANA-75D23L Panasonic battery SB
- Spark plug replacement
- N3X5-18-110 spark plug set
- Wiper blade replacement
- AY001-Z500R01 wiper blade
- AY001-Z450R01 wiper blade
- Wiper arm painting
- Air cleaner replacement
- N3A1-13-Z40 air cleaner
- Fuel filter replacement
- N3A1-13-480 fuel filter
- Radiator cap replacement
- KF01-15-205 radiator cap
- N3A1-15-205A radiator cap
- Compression test
- Shift lever wobble bushing replacement
- 0398-17-462A spring seat
- M501-17-515 bushing
- Rear lower arm left and right pillow ball replacement
- FD01-26-220 pillow ball
- 99574-3800 snap ring
- FD01-26-250 seal rubber
- Rear upper arm left and right pillow ball replacement
- FD01-26-230 pillow ball
- Toe control arm left and right pillow ball replacement
- FD01-28-42Y pillow ball bushing
- Left headlight opening/closing motor replacement
- FD01-51-SBXB retractable motor LH
- Driver's seat door pocket replacement
- F100-68-4MZC00 door pocket
- Wheel lock nut socket creation (McGard)
- ECM (Engine Control Module) replacement
- APEX Power FC
- FC Commander
- Installation of height adjustable suspension kit (supplied parts)
- Four-wheel alignment adjustment
That's what's next. Just got the invoice for this bad boy, which comes in at just over 20k EUR so far not including the work above.
Kei truck hunt is still on this week. Missed out on some of the previous ones, but it's fine as it gives me time to pay for this lot
I reckon HKS will sort me out an IC, the coilovers and I'm pushing for the ECU at the moment. This is mainly for the switchable maps and I think this is really a must have, so if they won't gift it as a part of it, I'd see if they'll do some deal because switchable maps is a must for me. They're super hesitant on the turbo kit, just because they don't want it to go wrong and if they can't trust it to be a good advert for their product, they don't want the risk, which I totally understand. I mean, any help would be mega for me.
Still have plenty of people to chat with as well... full time job all this
I'm off to Japan July 13th - 21st to see the beauty, meet up with Top Rank, HKS and some other guys. Super excited for that as I've never been, so should be fun.
Also got this back from Mazda director of PR today, so see where that goes!
Progress is progress!
