- 24 Sep 2015
Ok thanks.
Would I use the cloud key via the Archer, or should I get a UXG instead?
Sorry for the noob questions, not my forte unfortunately.
The Cloud Key is only of any use if you have certain UniFi devices such as an Access Point, Switch or some of the gateways. Some gateways (UDM for example) have the Controller built in so no need for a Cloud Key. Other gateways (such as the UXG-Lite) will connect to a Cloud Key and are managed from there.
If you just have the Archer then buying a Cloud Key would be a waste of money - it'd be sitting there doing nothing.
If you want to get a new gateway then get a new gateway but as the Archer is itself a router you likely have everything you need already to put the VM Hub into modem mode and offload the routing to the Archer. It's worth a try I'd say, you can do it without spending any money.
