- 8 Jan 2003
- Scotland
Last night my wife told me that while playing Cities Skylines 2, the screen went black and the PC just turned off and it won't turn back on. I took a look at it and noticed the light were still lit on the motherboard (underside RGB) but nothing was happening. I pulled the power from the PC and let it sit for a few minutes. I then plugged it back in and turned it on. The CPU cooler fan spins (which tells me power is getting through the board) and the power light on the button flashes. I get no beeps, other lights or any video output.
The spec of the PC is a Gigabyte B450i Auro motherboard, 5800X3d, 32Gb Corsair Vengeance DDR4, ASRock 6700XT Challenger.
I'm thinking it may be power supply but not sure as there is still obviously power getting through to the CPU fan. The power supply is the original Fractal 450w one that came with the case (Fractal Node 202).
Only thing I've tried so far is reseating the RAM. Next thing to try is to put the GPU in my sons PC and see if it works okay in there. Testing the CPU and motherboard are going to be more difficult.
