Badapter do quite a few modelsNo luck finding battery adapters for DeWalt yet either.
Hi. Can anyone give recommendations for a long reach hedge trimmer?
Not sure whether to buy a budget model. Seen one by VonHaus that seems to get decent reviews for under £100.
Worth paying extra for Bosch etc?
Needs to be battery due to location of use.
Primarily for trimming low hanging thin branches on trees that hang over footpath.
I’m not going to list mine, it’s easier to just not.You have a problem sir![]()
I’m left handed but I can and do use both hands for this kind of thing without issue, that is probably why I don’t even think about it. I suspect you are overthinking it.
P.s. if the saw isn’t well supported by the wood, cut from the other side. Clamp the workpiece down if you don’t want to operate the saw with your left hand.
Thanks and I just noticed I wasn't comparing like for like anyway, the Ryobi I was looking at isn't brushless whereas the DeWalt is. If I'm buying cordless tools I want brushless tools, as I've already made sure my drill, impact driver and multitool were all the brushless kind.
So the brushless Ryobi is actually much more expensive.
Another thing on circular saws - I'm thinking a right bladed model is best and am struggling to change my mind on that but there seems to be a lot of support for left blade designs. Which do you all have?
I've seen builders on YouTube using this but I have no idea what it is.
It's like a stop collar for your impact driver bits, so that you can't overscrew.
Anyone know what this is and have a link?
Is this what you mean::
Drywall Magnetic Screwdriver Bit Holder Adaptor Plasterboard Depth Stop | eBay UK
8mm x 50mm Magnetic Tek Screw Driver Adaptor. Adjustable depth adaptor ideal for Dry Wall Screws. Fixing Supplies. 1/4 Hex Drv 7 mm Magnetic Nut Setter x 100mm. 1/4 Hex Drv 7 mm Magnetic Nut Setter x 75mm.www.ebay.co.uk
Maybe. Does the screw head sit almost within the unit itself?
Isn’t overscrew down to your toque settings. Any powerful driver or drill will put that bit into the material you are screwing.I've seen builders on YouTube using this but I have no idea what it is.
The idea is that you don't need to hold the screw with your right hand when you are starting it off. Especially with modern screws that are self-drilling, this can hurt/damage your fingers.I've seen builders on YouTube using this but I have no idea what it is.
There is no way that I could tackle the jobs I have to do with a non folding or non pole hedge trimmer .In most cases, a pole trimmer doesn't give you all that much more reach. It may look like it does, but you are often better off just using that ladder you already own.
The holder has a magnet to hold the screw. But you probably know that if you rely on just a magnet, the screw has a habit of starting to wobble and flying off when you are trying to start it off. To stop that wobble, the bit holder has a sleeve that you manually slide out to cover the screw. As it's screwed in, the barrel is pushed back by the holder being driver forward, ready for the next screw.
Because you can't see the screw head, it's best used with a clutch.
