- 14 Jul 2005
- Birmingham
Here's what I'm talking about.
whiterosetools.com
Do you have a link for this thing, or is it what was posted above?
If not I'll try to find a screenshot of it. I've seen quite a few YouTube channels use them including properdiy.
Looks like a socket set nut driver TBH.Here's what I'm talking about.
most places that sell dewalt or other makes sell bare machines slightly cheaper , hence no battery or charger.I got a dewalt combi drill last year I think mine cost me about 140 or 150 and came with 2 batteries and the case. been trying to keep a eye out for other tools that dont include the battery to make use of the spare. I only use mine for small jobs so I dont need the 2
Tbh my Milwaukee circ is one of my worst tools. It is a fraction of the umph my dad's old Aldi special and bogs down way quicker. I may be pushing it harder than it was designed but like I said, it's my worst tool. It can't cut straight for toffee either but I'm blaming myself on that before searching for any technical reasons (tho I've done everything I can to try and get straight to no avail).The deals aren't great on anything but drills and impacts. I'd like a circular saw deal with 5ah battery but they aren't there.
Blade?Tbh my Milwaukee circ is one of my worst tools. It is a fraction of the umph my dad's old Aldi special and bogs down way quicker. I may be pushing it harder than it was designed but like I said, it's my worst tool. It can't cut straight for toffee either but I'm blaming myself on that before searching for any technical reasons (tho I've done everything I can to try and get straight to no avail).
On a related topic, is it worth routinley sharpening drill bits? I've never sharpened mine, so they're probably pretty dull, which I doubt is helping. They're a mixture of old high quality, but now blunt, bits (dormer etc) and some newish, but probably not very good Dewalt/Erbuauer/Bosch etc from Screwfix. Is figuring the angles out and using a bench grinder the best approach? Or one of those automatic jobbies where you just stick the drill bit in? I know for knives the automatic sharpeners remove a lot of material and are pretty agressive, so it's probably the same for drills?
Something like https://www.machinemart.co.uk/p/clarke-cbs20-electric-drill-bit-sharpener-3mm-/ vs a bench grinder
Blade?
Could be - I think some of the jobs I've put them through have been pretty tough too (plasterboard, wet treated c24, etc etc).Battery circular saws just lack power so it all comes down to using a thin kerf, very sharp blade.
A circular saw should require almost no pressure so I think it is most likely the blade just isn't sharp enough. And when you do push them, the thin kerf blade ensures the cut wanders off true.
Can anyone recommend a metal drill bit set suitable for drilling harder metals such as stainless steel? My admittedly probably not very good HSS drills aren't lasting very well. From a bit of research, it seems I'm after cobalt drill bits?
I've seen this set - https://www.amazon.co.uk/dp/B00239E4AS
.Can anyone recommend a metal drill bit set suitable for drilling harder metals such as stainless steel? My admittedly probably not very good HSS drills aren't lasting very well. From a bit of research, it seems I'm after cobalt drill bits?
I'm not a metal specialist, but don't you need at least Cobalt for stainless steel?
