The resale value will go up because nobody wants this idiotic branding shiz on their boards and you will have already fixed the issueDon't really want to damage the sticker tbh, will affect resale value if i do!
thats handy
wonder if theres something else to prevent vinyl
from sticking to asus label
little dab of grease or something maybe?
though guess it might dry out but not sure if it dries
will that part of vinyl "blow"
guess your mate will know though
The resale value will go up because nobody wants this idiotic branding shiz on their boards and you will have already fixed the issue![]()
. Would probably be slapped with Asus tax too
.i guess you wil lolWith a bit of heat it should be fine, just need something that's less Tacky than the asus label and it shouldn't pull the label off. Guess i'll find out![]()
i guess you wil lol
and like lephuron i would rather have it altered
than look at that rainbow puke branding
something i really hate.Quick drop of photos, board, fans and memory debut right here. Temporary 12700K in there while i wait for the replacement 13700K to arrive. Long story short i received a dud 13700K.
Kingston our new collab has sent us a set of DDR5 6400mhz 64gb CL32 2 dimm kit! Can't wait to test it properly when the new cpu arrives, lovely set of SK Hynix set so should be a monster clocker too.
Bitspower is busy with Computex right now but we're in the middle of confirming watercooling components for this build
And yes no RGB with this build, just pure class!
looks good mate. Thanks for the pics
.Chonky heatsink, love seeing air coolers being used.
Boo AIO, yay HSF and hard-line loops
Really? Looks bigger, maybe my brain exaggeratesNot the largest heatsink in the world as it only supports 92mm fans BUT it's more than enough to keep a 12700K cool under full load while running R23 bench at around 72c. I was expecting far worse tbf
Still undecided whether i will hardline or soft tube this build.
1 vote for hard-line here! Would mirror the straight lines of the case
I would definitely use chromed or stainless steel tubing for the CPU block, vertical runs down to whatever to match the tubular frame. Connections to pump/res and radiator can be tucked away at the bottom with some EDPM.
But that's just me![]()
Who watches the watchers...
That's a camera
Other than that I have no idea lol
Bought myself a fancy camera to take photos
Of my stepsons wedding
It's sat on a shelf since
Had no clue how to use the ####### thing
Surprised the photos actually came out fine tbh
On a totally random subject lol
Have you seen new phanteks fittings?
Quick release/connect like pushfit plumbing fittings
But you can use both 16mm hard or 16mm soft tubing
No more needing separate fittings for soft tube and hard tube
Yeah that's it ez fitIt's not the best video and photography camera, however for mirrorless and at the price point i got it for brand new i cannot complain lol. Did some test footage and some standard shots and dang its good! just need a decent lens to go with it.
If you had your camera set to auto and point and shoot then you can't go wrong really lol
I haven't, gonna google them now! That sounds absolutely amazing! I was wondering when someone would actually come up with something like this. You got a link for them?
Edit: Ah i think i found it, the EZ Fit stuff?
