Man, this definitely is a learning curve. Finally got my Reolink cameras and Sonoff Zigbee co-ordinator installed. Have got a Shelly relay which i'm hoping to wire into the gate switch to control that. Won't have as much control on whether it's open/closed, but should be enough to just have the "switch" input for now.
The timer is also broken on the pool, so debating sticking a relay in for that too with the pump on manual mode. Saves me remembering each morning. Figure a couple relays can be re-used so not wasted cash on the rental.
Can see why some of you guys said to make all the mistakes now and then start from scratch when my actual house is built!
