Managed to snag one of these today but not sure I'm that sold on it:
My eyes!
Are you not sold in general, or the colour? I have the Pluto one which I really like, I've been thinking of getting an Earth.
I don't want a nato, mind you.
Appreciate all that, but it looks gash.What do you guys think of this for the money?
Longines Conquest 41mm Mens Watch L37194966 | Watches Of Switzerland UK
Longines Conquest 41mm Mens Watch L37194966www.watches-of-switzerland.co.uk
I've been temped by one in the past, some might scoff at it being quartz but this is a VHP (very high precision) quartz movement, one of the most accurate in the world, losses around 5 seconds a year, some people say only 3 seconds compared to +/- 15s a month for a regular quartz, it also has a perpetual calendar so you don't have to worry about changing the date.
It has a magnetic detection and correction system, for example if the watch detects magnetism it will stop the movement and reset the hands back to the correct position after the magnetic field is no longer detected.
It has a shock correction system, if the watch has an impact it will reset the hands back to the position they were in before the impact, this is possible due to the gear position detection system that enables the movement to constantly recall the last position the hands were in.
And if that's not all it you can pull the crown fully out and it puts the watch into dormant mode, after 1 min all hands will go to noon to save the battery, once you push the crown back in the hands will move back to the correct time.
And finally it has two stages of end of life battery indication, first stage is the seconds hand jumps in 5 second increments, and finally last stage all hands advance to noon and the watch goes into sleep mode, at this stage you have 6 months to change the battery, this is some crazy tech for a quartz watch!
dLockers summarised it nicelyWhat do you guys think of this for the money?
I quite like the looks, but if it's the tech that impresses you then Citizen does even more for half the price. If you want Longines on the dial however, then that's your answer.
Yep like roles don't use rubber straps, there oyster flexI still laugh at them still marketing "bio ceramic" - It's plastic but no that would be too normal a name to use![]()
It is Titanium and Nickle core tho tbfYep like roles don't use rubber straps, there oyster flex
Gash is a bit strong, but yeah wouldn't be my choice eitherAppreciate all that, but it looks gash.
For that type of watch, something from citizen or Seiko is probably a better bet.Interesting, yes the tech is what I like, I didn't know Citizen did cheap high accuracy quartz watches, have you got an example for me?
CB0253-19A is solar / atomic (radio) controlled. Seiko also do a bunch of similar watches- SBTM323 for example.Interesting, yes the tech is what I like, I didn't know Citizen did cheap high accuracy quartz watches, have you got an example for me?
If you want the Longines just buy it man - whatever makes you happy (y).From what your telling me it sounds like the Longines can't be beaten on accuracy for the price unless the movement uses outside intervention (radio) to aid it?
I think you should buy whatever you want, visuals of a watch are subjective, if like the look of the watch, the features and the tech, then go for it.What do you guys think of this for the money?
Not sure why people are bothered by accuracy that much to be honest. As long as it doesn't lose or gain more than 5 seconds or so a day.
I did have a citizen radio controlled watch years back and the tech was kinda cool though![]()
