- 20 Jul 2009
- Midlands
Are you sure it’s just not the set bead?
So I was going to change the tyre on my sons Canyon hardtail and found the tyre bead wouldn’t unseat at any point off the rim. Eventually I tried the other side of the tyre and it came off easily.
Turns out one side is stuck onto the rim - is this normal
Looks like this summer riding will be off, torn my achilles tendon . So no more rising for foreseeable future .
Anyone able to recommend a set of bars?
I have the standard Specialized 6061 30 rise, 35mm stem that came with the bike at 816mm with grips and 6-degree upsweep, 8-degree backsweep. Its crashy, the offsets are playing murder with the carpal tunnel..
I've since gone for an Renthal FatBar Lite Carbon35 with 30 rise at 776mm with grips and 5-degree upsweep, 7-degree backsweep and am not finding it to be very compliant like I expected it to be and like other brands can be however its much nicer on the wrists now I have been able straighten my wrists out more. I have however found I am getting slight fizzing in my pinky due to some stress on the Ulnar Nerve. Its better than Carpal I can assure you but its not ideal.
THIS - https://www.renthal.com/cycle/handlebars/fatbar-lite-carbon/fblc35-30mm
Would it be worthwhile chopping my Specialized bars down to the same width as the Renthal to see if that geo and width works better and then finding something nice to replace it?
Any suggestions on brand and model would also be appreciated.
Woke up this morning and saw my garage door was open and unfortunately what you all think has happened has happened and i've had my bikes nicked overnight. Looks like they've forced their way in through the window and then taken the bikes over my back fence.
I'd add the new PNW Carbon bars as well. I find them very comfortable they have a little more back sweep which I like.Supposedly the one up is one of the best. I had the rental 35s before and found them absolutely fantastic though.
Lock-on grips spaced out 12.5mm either side would fix your issue. Half the people running tapered grips don't know they need to really push them on (i.e. with a mallet) and end up running bars way wider than they really think.There’s a place called north yorks physio and they do bike fits. It costs £120 to get what is essentially a weird sliding thing fit to you which is helpful for posture and correcting it plus dealing with any pre-existing condition etc.
Long story short, based on shoulder width, length of bike etc, an 785mm bar at 8.5 degree back sweep and an 5 degree upsweep would be perfect. And as with anything “perfect” it doesn’t exist.
It does however mean that the FatBar with an extra 12.5mm either side would be pretty much perfect having been a half degree out with some adjustment to the stem angle. You can’t just “add” carbon so it means £144 for a new one in 800mm that can get a small trim. Errr, no.
Nice. What do you think of the shock my new frames coming with the same, and also 130mm.![]()
I posted this in GD but thought it made sense to repost in here:
New bike day!
Bird Aeris AM 160.
One of the first in the country, ordered back in November so it’s been a long wait but it’s finally here.
Had a blast today giving it a shakedown. Really pleased with it. Worth the wait!
Hey. Has anyone ridden in the Quantock Hills before? I’m wondering which 2-3 routes are the “must dos” if you only have 1 weekend available. “Minehead Madness” seems like an obvious choice![]()
