No substrate on the bottom or is that being added next?
Ordered it earlier in the week, wasn't till today they informed me it was out of stock.
Gonna go at the weekend to see if I can grab some.
To me, the focal piece (bogwood) is too central, but beauty is in the eye of the beholder! They used to say place focal point around 2/3rds to one side.
I'd try the bogwood rear-right on the diagonal, tall single rock in middle on diagonal, flowing into the three smaller rock pieces front-left.
I know my water is very hard, when I had my shrimp tank, I bought RO water and used a shrimp product to remineralize it.
I'm not sure whether to use a similar product for the new tank, or cut it 50/50 with tap water.
Going off my own experience i'd say dont fight your local water parameters to much, find fish that suit them otherwise your just fighting a loosing battle every water change and the stress it puts on the occupants.
I use an HMA filter to remove chlorine etc and don't add anything except plant food. Don't try to change the water chemistry, it won't stick anyway and it will prevent it finding a natural balance.
Infact I don't even do water changes much now, maybe once a month. Not had any illnesses or deaths for a long time and plants grow like crazy.
I was once told by a local fish store that people worry too much about their water hardness etc. Your rarely buying a fish that doesnt come from a seller local to you so therefore it makes sense that they are breeding their fish using similar water parameters to yours. I tend to ask the seller what type of water they have been kept in, one thing is your harder water would be great if you ever decide to go down the African Cichlid route. I have to buffer my water loads to get to the right parameters, yours is coming from the tapStill slowly buying stuff for the tank and looking at plants, but I'm wondering how to tackle my water.
I tested my water the other night an API kit and both the GH and KH were off the scale.
They only go up to 12 drops, which means 12ºdKH, or 214 ppm. Where as my water took 18 drops to change the GH test colour, I think the KH test, took 16/17.
I know that plants like hard water, but I'm concerned about my future betta.
By the way, how does this look? Does it look too busy?
you could get some shell dwellers at some stage which stay small, really great behaviour in them as their tank is basically just sand and a load of snail shells they will totally scape the tank themselves and stay small. Neolamrplogus Multifasciatus or Multis. If i ever replace one of my 20g tanks thats what ill go for some shellies or Tanganyikan cichlidsI would love an African Cichlid tank, but at the moment I don't have enough room for a decent size tank. Don't think i'm gonna fit many in a 10g.![]()
Same here. The plants and biofilter sorts the water for the most part. I only add plant food. The plants are growing at a staggering rate, fish and shrimp all doing well.
Sadly losing the torch coral in my saltwater tank, I think the corals are attacking each other. First coral loss in a year though, but all the others are thriving![]()
Reading different things on substrate depth.
Some people say 2-3" minimum, while other people are saying 10cm!
That's a 1/3 of my tank height.
I did soil once, never again. It’s also risky as you don’t know what’s in the soil and it can leach huge amounts of ammonia into the tank from decomposing material.
The whole filter thing isn’t anything to do with the soil, the substrate is irrelevant. All a biological filter does is add surface area for bacteria to grow. So as long as the tank has enough surface area in total or has enough plants to take up the ammonia, you don’t need a ‘filter’.
You absolutely do need some method of circulating water though be that a pump or air stones.
The size of the filter needed for a fish tank is usually grossly overstated on the internet.
