I ended up getting a 360mm AIO for the chip. Its made a huge difference to the temps! I miss the aesthetics of the WP though, but the cooler still looks good and when under load the PC is WAY WAY quieter than the WP blasting away!
Unpopular opinion: People get far to obsessed with having low CPU temps at high loads.
Unless you are hitting 95c+ in torture tests, just calm down, it's normal.
I’ve found them not that bad. The AMD cooler was an ideal included HSF. Much better than the included day one e-waste Intel shipped. It used to really cheese off throwing brand new heat sinks and fans in the bin.
