Should be fine as the chip only hits around 80w max despite the 105W TDP.
I have a 5700X3D on a wraith stealth cooler temperature and it's completely adequate for gaming at default OOTB settings.
By "on average", what kind of load are we talking? The same question with the peak/maximum.Running my wraith prism in this chip. I am seeing low 70s on average and peak or maximum of about 79-81 degrees..
Is this still safe operating temps for the cpu?
Low 70s is fine for gaming on stock settings with the stock cooler.I’m not sure. Just general gaming.
I will try some monitoring to get more info together.
this. the more important metric is noise imhoUnpopular opinion: People get far to obsessed with having low CPU temps at high loads.
Unless you are hitting 95c+ in torture tests, just calm down, it's normal.
Yep, people get really stressed out over the high numbers even though it does no harm to the chip.Unpopular opinion: People get far to obsessed with having low CPU temps at high loads.
Yeah, the noise levels have dropped significantly under load. It’s crazy!
the Wraith prism is a loud cooler in its full speed mode, i could not stand it myself
Not really. CPU's have V/F curves and boost tables which prevent exactly that from happening, assuming you aren't ignoring default specCan be a significant factor. Temps+power+frequency will kill chips.
As is current, voltage and thus power draw. That's why we have V/F curves and boost tables.No, really. Heat is a significant factor in semiconductor survivability.
