- 30 Mar 2017
That is a bit worrying. I tried undervolting via vf curve and it won't accept any value at all.Have you tried AI OC ? It’s surprisingly good. Less of a hassle too.
LLC levels is just default DC_LL on asus so you will need to adjust AC_LL if volts or power is a concern.
Also if -0.01 isn’t stable then there’s a good chance stock is not stable either and you might have a duff cpu.
The CPU seems to be stable at complete stock though.
I have limited the power to 253W for PL1 and PL2.
Doesn't seem to be much room to do anything else to be honest.
I tried overclocking but it needs over 1.5V for 6GHz all core so just wanted to try and get stock working at lower temps!
