Caporegime
- 18 Oct 2002
Mesh shaders are native in RDNA3 too @humbug , emulated in 2.
I'm definitely happy with the XTX performance overall now they seem to have gotten a good handle on the drivers, very tweakable too for more oomph![]()
Its equivalent to an RX 6650 XT, that card is $220, the A770 is $270
Game performance improvements on Intel® Arc™ A-Series Graphics Products versus Intel® 31.0.101.5762 software driver for:
Yakuza: Like a Dragon* (DX11)
Up to 91% average FPS uplift at 1080p with Ultra settings
Up to 35% average FPS uplift at 1440p with Ultra settings
Metro: Last Light Complete Edition* (DX11)
Up to 20% average FPS uplift at 1080p with High settings
Up to 23% average FPS uplift at 1440p with Very High settings
If you looked at only the 1080p Geomean average you would think these are cards are neck and neck but when you look at the actual results the difference in performance between varies wildly.Tom's Hardware compares the A750 with the RX 6600.
Arc A750 vs RX 6600 GPU faceoff: Intel Alchemist takes on AMD RDNA 2 in the budget sector
Intel drivers have improved, so let's discuss how it stacks up against AMD at the $200 price point.www.tomshardware.com
TLDR: the A750 compares well performance-wise but they have driver concerns.
Gaming Highlights:
Intel® Game On Driver support on Intel® Arc™ A-series Graphics GPUs and Intel® Core™ Ultra with built-in Intel® Arc™ GPUs for:
Stormgate*
Game performance improvements on Intel® Core™ Ultra with built-in Intel® Arc™ GPUs versus Intel® 31.0.101.5762 software driver for:
Stormgate* (DX11)
Up to 12% average FPS uplift at 1080p with Medium settings with Temporal Super Resolution enabled
6 months away at least, I'd put money on it.Battlemage GPU spotted!
Intel Battlemage GPU has surfaced in the wild — GPU spotted with 24 Xe2 cores, 19 Gbps memory, 12GB VRAM, 192-bit bus
If reports are true, it will be a mid-range Battlemage GPU with 32 Xe2 cores on the top die.www.tomshardware.com
Intel are working on the teaser train.
