Spec Check New Laptop
5 May 2022
Haywards Heath
Thinking about new laptop for art & design , spreadsheets also video editing
Spec beow
Ultra 9 processor 185H (24MB cache, 16 cores, 22 threads, up to 5.1 GHz
Intel(R) Arc(TM) Graphics
1TB M.2 PCIe NVMe Solid State Drive
32GB, 2x16GB, LPDDR5X, 6400MT/s
14.0-inch 16:10 2.8K (2880 x 1800)
Will be using external monitor 4K
Spec beow
All depends on the balance of work e.g. Design, video editing vs Spreadsheets.
On your budget would swap to an RTX laptop and 16" screen. Maybe you can maximise your budget going Core 7 Ultra and have improved GPU to accelerate work flow or more storage?
Spec beow
These new ARC equipped Ultra 7 and Ultra 9 are, in real world use, brilliant.
But for video rendering and graphic/design productivity then one of the RTX 4050/4070 low power c50w cards for the studio features give notable benefits.
Reviews are all over the place though as there is specific ultra portable & design productivity purpose to these low wattage RTX cards and they get review conflated with gaming machines but don't compete.
Would this be a better option to go
Lenovo Ideapad Pro 5 16"
Intel Core Ultra 9 185H processor with Integrated Intel Arc Graphics
32GB RAM Soldered LPDDR5x
2TB SSD Storage
16" 2.5K (2560x1600) IPS 350nits Anti-glare, 100% sRGB, 120Hz
2TB SSD Storage
Great screen and 16" is the sweet spot. I use a GBT Aero 16" for work and the screen is the icing on the cake for me. Strong spec that
Hmmm for creative work I would really focus on RTX and turn Studio Drivers on. I think you will find like for like comparison to be improved with this solution e.g video editing etc
I will not be playing games on laptop
RTX enabled for the Nvidia Studio features significantly accelerates production & design capabilities. ARC is no where close, nor are AMD equipped GPUs in laptops.
Gaming is secondary.
Loads of conflation over the low wattage RTX equipped laptops being benchmarked with gaming machines then performing poorly but it's not their purpose.
Ultra 7/9 with RTX4050-RTX4070 hits the design productivity sweet spot especially if ultra portable guise.
They are about another £300 + ( RTX4050-RTX4070 ) then the Lenovo Ideapad Pro 5 16"
