Interesting. The tests I've seen never went as high as 8000MT (likely they weren't lucky enough to push that high on their particular CPUs). Good to know it can go (with luck) that high and it gives proper perf. increase
BTW, related to x3D - upon updating BIOS to AGESA 1.2.0 I can now see in Windows it defaulting always to 3D cache cores, irrelevant of bios settings, drivers and even app that can manually choose between perf and 3D cache cores (through drivers). Problem is I also updated drivers and Windows to new build at the same time, so not sure now if it's that BIOS issue or the AGESA messed it up a bit or Windows...
Not that it cause any issues in games but outside games I liked it to use perf. cores as priority, which doesn't happen now. Oddly, not seen any reports about it online, so it might be just MSI messing things up a bit here.
