From what I understand there are two issues going on at the same time. They might be connected. But they need to be solved individually.But it's a Crowdstrike issue. Yes affecting Microsoft servers but it's not their doing.
Unless I'm wrong about that?
So it's purely a cloudstrike problem?You are wrong, the media reporting before they had all the facts.
Anyone slightly concerned how reliant we are on all this IT infrastructure yet how easy it seems to be to disrupt?
The fix:
How to fix the CloudStrike Windows BSOD issue
Fortunately, CloudStrike has since announced at 2:30 a.m. ET that it has identified the update causing the issue and rolled it back. The company also offered a workaround for anyone having problems:
- "Boot Windows into Safe Mode or the Windows Recovery Environment
 - "Navigate to the C:\Windows\System32\drivers\CrowdStrike directory
 - "Locate the file matching 'C-0000029*.sys', and delete it.
 - "Boot the host normally."
CrowdStrike Falcon is mainly used by businesses but some allow their employees to use it.
del "C:\Windows\System32\drivers\CrowdStrike\C-00000291*.sys"
	This specific issue isn't MS but rather CrowdStrike.Microsoft will end up collapsing at some point unless they don't start up'ing their game.
the premarket price is just the price you could have bought at in april, it would have to fall a lot more (which it might) to be seen as a discount imo, I'd say wait and see. My prediction is it should be possible to get it for under 200, or even 100 because imo it's massively over-valued.Ooft.
Do I buy some crowdstrike shares.. Or is this reputational damage?
Yes. Simply renaming the Crowdstrike folder (or deleting the file as posted) and then rebooting the server, fixes it. We have had about 20 of 200 servers affected.So it's purely a cloudstrike problem?
Probably a DEI hire at Crowdstrike.
	I think the advertising terms "the cloud", or back in the day "cyber space" are deceptive terms and people get a false sense of security.This is why moving everything to "the cloud" is anabsolute disaster waiting to happenis a terrible idea.
Particularly when so many services all end up at the same end provider.
Have you seen their share price? They aren't going anywhereMicrosoft will end up collapsing at some point unless they don't start up'ing their game.
