From a Don no less...
It's been pretty bad reporting by a lot of the media outlets. They all seemed to have jumped on the Azure outage and blaming that/MS even though by 6/6:30AM it was fairly well known CrowdStrike were having issues and MS was well into restoring their Azure services - was already up monitoring Azure services in the states and the cybersec lot were already posting about CrowdStrike.You are wrong, the media reporting before they had all the facts.
Trialed Falcon (MacOS) a while back and it wasn't a bad product; costs and budget prevented us going with it though.We had CrowdStrike for a couple of months last year as part of a security assesment. Glad it's gone today!
More and more big companies releasing explanations like
"Third party software/Crowdstrike is to blame for this outage, blah blah"
No. YOU are to blame for installing kernel mode malware across critical systems on our network!
Yeah it's not even down to 3 month low. And PE is extreme.the premarket price is just the price you could have bought at in april, it would have to fall a lot more (which it might) to be seen as a discount imo, I'd say wait and see. My prediction is it should be possible to get it for under 200, or even 100 because imo it's massively over-valued.
Crowdstrike down 20pc now. That's a big fall by any definition really.
Seems like the media have finally picked up on its not MS issue.
I mean it's really down to if customers have an alternative, and if this damage is bad enough for them to go.. Nope.. I want a different provider.
That is the big one. And I'm not sure. Changing provider is a lot of work. And you'd think if this has happened once they'll put measures in place to not let it haagain.
Very tempted though as I was thinking about buying in recently
You can see the impact on the share price. Dropped to 300 as those in the know sell up. Now the news is more common knowledge it's tanking more.Took them a while huh.
There's no also zero guarantee that the new provider won't push a borked update either. You could rip & replace your endpoint protection on 000s of devices but just find yourself in the same boat in some point in the future...
Go back far enough to Windows XP and you'll find when McAfee pushed a definition update for VirusScan which identified svchost.exe as a threat, so quarantined it...
FYI I have bought in now. 20pc off is enough for me to have a go. Maybe too early. But here I am.Question is where will it be when the markets actually open in the US.
Imagine how bad it will be when there inevitably is a proper mass cyber attack from China, Russia etc.
We've built ourselves a fragile existence.
Yes I thought the same, it's a virus checker problem was said many times.Watching the mainstream media report this is hilarious.
