Can someone else help us out and point out this evidence they have apparently posted that states the EU agreement allows for alternative solutions? There’s mountains apparently.
I think you'll find that's in the new testament, Gareth 1:16I posted the wording of the agreement just a few posts above, that simply says Microsoft have to offer the same access to APIs to others that they use themselves for their security products.
If they chose not to develop suitable APIs because it was easier to let their software have direct access, it's on them that they have to offer others the same direct access.
Nothing says 'thou shalt offer kernel access'
Worth reading the actual agreement as it tells you exactly what they can and can't do - https://news.microsoft.com/download...osoftInteroperabilityUndertaking16Dec2009.doc.Where is your evidence that the agreement with the EU says they could do that?
Microsoft allows signed boot drivers (eg - Crowdstrike's driver) in kernel-space to drag in data from user-space and execute it
Yep, after what we saw on Friday, that possibility has to be on everyone's risk register.This is the really worrying part, this could have been significantly worse other than a few dodgy files causing a boot loop, what if this backdoor essentially was used maliciously for malware or worse, ransomware. This could have caused an insane amount of damage that could have taken many weeks if not more to recover from.
***You were warned to drop it***The TL;DR is, security related API's used by Microsoft should also be made available to third-party vendors and they should be publicly documented unless publication is a risk to security.
Microsoft is trying to save face and as @Murphy and others have stated, this EU agreement wouldn't stop Microsoft securing those API's, just that they have to make them available to others.
Whether a third-party could maliciously attack this process is definitely a 'yes, no, maybe' but if the reports are correct then it's seems Crowdstrike opted for this solution because there wasn't another available to them, ie - kernel access whilst providing efficient updates without going through the timely WHQL process.This is the really worrying part, this could have been significantly worse other than a few dodgy files causing a boot loop, what if this backdoor essentially was used maliciously for malware or worse, ransomware. This could have caused an insane amount of damage that could have taken many weeks if not more to recover from.
Unless there's more to this agreement that hasn't been made public then (again) the gist is simply, any security related API's Microsoft produce(d) within Windows has/had to be publicly documented, where there isn't a risk in doing so, and available to third-party vendors to prevent Microsoft gaining a competitive advantage with their security products by using undocumented or unavailable to third-party access to their OS/platform.Anyway, so are you saying in 2009 when the deal was signed that MS Defender (or whatever it was called) was using API's? Or are you saying that MS could have redesigned one of its existing apps to remove the inherent security risk that was caused by the EU agreement?
Still waiting for the furious rebuttal from the EU - MS's comments have been reported globally and they are not normally so coy..
I'm more than happy to be proven wrong but i cannot see, in the published document, where it alludes to or states how secure or unsecure these security API's need(ed) to be.
So if there is an inherent security risk with these API's then that is surely on Microsoft not this agreement with the EU, which is there to prevent anti-competitiveness?
Majority of the reporting on Microsoft's comment appears to stem from the same WSJ article and source but that aside, ultimately Microsoft can blame their part on the incident on whatever or whoever they like. The published EU agreement doesn't seem to support their reasoning/excuse though.
By all means, read the EU agreement yourself, maybe you're able to find something that does![]()
not sure that idea, also in earlier linked MS employee video, holds water, usually program stack/data space is managed differently to code areas, for branch prediction/caching etc.) in kernel-space to drag in data from user-space and execute it
Did you read the EU agreement, i did post the link, at all? Did you manage to find anything that suggests the EU is at fault and supports Microsoft's comment? You should post the section of the agreement if you didMaybe start by answeriing my questions rather than designing an irrelevant scenario based on your skim reading of the agreement?
What i've said is in my replies, hope that helpsAre you saying in 2009 when the deal was signed that MS Defender (or whatever it was called) was using API's? Or are you saying that MS could have redesigned one of its existing apps to remove the inherent security risk that was caused by the EU agreement?
What i've said is in my replies, hope that helps![]()
Is that not the same as blindly accepting the comment of a company involved in a global incident that is most likely in a little bother attempting to save their own backside, especially to shareholders who no doubt have their own questions, and shift blame elsewhere?Blindly defending some third countries trade organisation that has nothing to do with you is just bizarre.
I've never owned an Xbox...Also I get a lot of you are butt hurt that MS has ruined the Xbox brand...
So it's really not unreasonable to suggest that the EU is in part culpable for this mess.
