Gigabyte MO34WQC2
4 Feb 2011
MO34WQC2 Gaming Monitor​
  • Panel Size (diagonal)
    34" OLED
  • Display Viewing Area (HxV)
    800.06 x 337.06 mm
  • Panel Backlight/ Type
    OLED
  • Display Surface(non-glare/ glare)
    Anti-Reflection
  • Color Saturation
    99% DCI-P3
  • True Resolution
    3440 x 1440 (WQHD)
  • Pixel Pitch
    0.2315(H) x 0.2315(V) mm
  • Brightness
    250 cd/m² (Typ, SDR APL 100%); 1000 cd/m² (Typ, HDR APL 3%)
  • Contrast Ratio
    1.5M:1
  • Viewing Angle
    178°(H)/178°(V)
  • Display Colors
    10bit (1.07B)
  • Response Time
    0.03ms GTG
  • Refresh Rate
    240Hz
  • HDR
    VESA DisplayHDR True Black 400
  • VESA Certified ClearMR
    ClearMR 13000
  • Flicker-free
    Yes
  • Connectivity
    2 x HDMI 2.1
    1 x Displayport 1.4
    1 x USB Type-C (Alternate Mode; Upstream port; Power Delivery up to 18W)
    2 x USB 3.2 Downstream ports
    1 x USB 3.2 Upstream port
    1 x Earphone Jack
    1 x Microphone Jack
  • Earphone Jack
    Yes
  • Speaker
    3W x 2
  • Unique Features
    Tactical Switch
    OSD Sidekick *
    Black Equalizer 2.0
    Dashboard
    Crosshair
    Timer
    Counter
    Eagle Eye
    PiP/PbP
    Auto-Update
    KVM
    6 axis Color Control
    Apply Picture Mode
    HDMI-CEC
  • Power Type
    Power Board Build-in
  • Power Consumption
    48W **
  • Power Saving Mode
    <0.5W
  • Power Off Mode
    <0.3W
  • Voltage
    AC 100-240V ~ 50/60Hz
  • Tilt(angle)
    -5°~+20°
  • Swivel(angle)
    ±30°
  • Height Adjustment (mm)
    130 mm
  • VESA Wall Mounting(mm)
    100*100 mm
  • Kensington lock
    Yes
  • Phys. Dimension with Stand(WxHxD)
    811.7 x 595.3 x 244.3 mm
  • Phys. Dimension w/o stand (WxHxD)
    811.7 x 361.2 x 105.8 mm
  • Box Dimension (WxHxD)
    990*527*238 mm
  • Net Weight with stand (Esti.)
    9.86 kg
  • Net Weight without stand (Esti.)
    6.68 kg
  • Gross Weight (Esti.)
    12.5 kg
  • Accessories
    Power cable/HDMI 2.1 cable/DP cable/USB cable/QSG/Warranty card
  • Note
    *To enable OSD Sidekick (integrated in GCC), it requires connection between PC and monitor with HDMI/DP cable.
    **The test condition follows CEC standards.
I have the MSI equivalent, which I'm guessing is the same panel. I absolutely love it and wish I had gone for one sooner.
