- 6 Jan 2013
- Rollergirl
Is there an upgraded model due out this year?
GTAV runs well. No idea about JC3. I'm the same, but given that I don't play much mp anymore I've given myself to the sticks / pads / gyro. It's easier than you think, but if nothing is stopping you from using a desk I'd just stick with that tbh.Thinking of getting the Oled version. Not the 1tb though.
Not gamed for approx 8 years or so as i not had a pc or console since then.
I do have a steam account from back then which i can still access.
Thing is, i was always a keyboard and mouse gamer. Tried Playstation controller some time ago on a friends and struggled aiming when shooting..lol
I used to play JC3 and GTAV. Miss those games. How are they on the deck? I like driving games too.
I am a complete noob when it comes to the SD. I have checked out youtube looking at reviews of them.
Any advice appreciated...
Remember you can connect a controller, keyboard and mouse (and also a monitor) to your SD if you want. Obviously takes up more space but far less than a full system
Nothing announced yet. With the next generation of mobile chips already out, you'd think they're already working on the next custom APU for Steam Deck 2. Who knows though with Valve Time.Is there an upgraded model due out this year?
Had my first major issue with the Steam Deck. Was moving a large game from the SD card to the internal SSD. It was taking a long while so I left it to do overnight. Next morning I saw it went to sleep, woke it up and said it successfully moved the game. But then I noticed for some reason in the download list it was downloading the game again. Across the Steam UI I also noticed broken images suddenly. Tried rebooting the Steam Deck, but then it got stuck on the boot logo. The battery storage mode trick didn't work, using "..." + power button to try a previous image also got stuck. I also saw try using fsck from the recovery image (it did find errors in the esp folder) but it didn't work either.
In the end I decided to just reinstall SteamOS. Luckily I was able to back up my personal files via the recovery image to an external storage, but it'll be a pain to set up everything again. One weird thing I did notice however was after applying the fresh image, rebooting the Deck made it stuck on a black screen. Force shutting down or shutting down from within Steam and then turning on was fine. Seems to have disappeared after I had the bare basics set up though, it's now behaving normally.
do we think they are waiting on the switch 2 before annoucing anything else or they dont really care?
yeah, although it cannot play pc games they wont wanna release something that has worse specs.For a steam deck 2?
If you don't mind wiping the Deck you could reinstall SteamOS (current recovery image is based on 3.5.7): https://help.steampowered.com/en/faqs/view/1B71-EDF2-EB6D-2BB3I dont use my deck much really, but ive noticed for a while that it wont run an update.
checking now, it seems to be stuck on:
OS Name - "SteamOS Holo"
OS Codename - Holo
OS Variant - Steamdeck-rc
OS Version - 3.4.10
OS Build - 20230831.1
Kernel Version - 5.13.0-valve37-1-neptune
Bios Version - F7A0113
This seems like its old... i cant get it to update whatever i try. Changing the update channel to Beta didnt help.
Any advice?
Thanks
Has it got free space? Mine has done some very strange things in the past when running low...I've got an SSD on the way. I'll fit that and start again.
It's all working fine, other than being out of date.
Thanks
Its the 64GB model, but ive installed everything on the SD card. so it should have. I have a 500GB SSD to go in it, so that should resolve that too if its an issue.Has it got free space? Mine has done some very strange things in the past when running low...
