12700k question
I imagine there won’t be better deals for Black Friday? I still am on the fence!! Even if I won’t be able to get the mobo and ram for a few months :)
Unless your buying used and cheap there is no reason to buy 12th gen…
Get a 7600 and a B650 board. This will work out cheaper and give you more future options
Your looking at a £270 z790 board so go with a run of the mill cpu.
So your looking at £440 plus the cost of ram…
Buy a 7800x3d and a £100 B650 board for the same cost.
Use a B760 which work with 12th Gen.
  • SKU: MB-6KG-AS
  • EAN: 4711081982661
  • MPN: 90MB1CX0-M1EAY0
Intel 12th + 13th Gen compatible, LGA 1700 Socket, B760, PCIe Gen 4, Micro-ATX, 4x DIMM slots, DDR4 5333MHz(OC), 2 x M.2 , 4 x SATA, 2.5Gb LAN, WIFI6, 2x HDMI, DP, 6x USB
£106 (incl. VAT)
  • SKU: MY-0AK-TG
  • EAN: 0765441645943
  • MPN: TLZGD416G3200HC16CDC01
16GB, 2 x 8GB RAM Modules, DDR4, Dual-Channel Configuration, 3200MHz, 16-20-20-38 CAS Timings, Compatible with Intel XMP 2.0 Overclocking
£50 (incl. VAT)
£40 (incl. VAT)
  • SKU: MEM-8PK-02586
  • EAN: 0765441773318
  • MPN: TDPPD432G3600HC18JDC01
TDPPD432G3600HC18JDC01, 3600MHz RAM Speed CL 18-22-22-42 Timings, 1.35v VDIMM, 8 Pack Approved, Lifetime Warranty with OcUK.
£120 (incl. VAT)
Motherboard and RAM can be had for under £160, even cheaper if not requiring onboard WIFI. :)
Yer I’m not saying it can’t be done, just Tommy was talking about ddr5 and pice5.0
The board he said he was looking at is £270
Plus £100 for 32gb of 6000mhz ram
And £170 for the cpu
he wants to upgrade to 14th gen down the line
All I’m saying is spending that much for a 12700 based system is madness when he could have a 7800x3d system from you for the same money, or even a 5700x3d for less
