- 14 Jul 2005
- Birmingham
Edit:
Not too far wrong - checkatrade suggests £700
https://www.checkatrade.com/blog/cost-guides/ridge-tiles-price/
its because my roof has a lot of ridge tiles (marked in red):
Ive had two quotes so far. Quote 1 was for £2300 reusing the existing ridge tiles and fitting dry system. Quote 2 was for £2600 but was all new ridge tiles (because he expects some to break on removal) as well as dry system. Im getttng a third quote later this week.
I dont know what Im supposed to do. If you tell me it should be £700 but my quotes are all coming back £2k+, what am I supposed to do? I think one look at that job will suggest no-one is going to do it for £700 that's a completely unrealistic price in my view.
Im not a builder, I have no building experience. I don't know how bad a wall needs to be before it becomes a risk. To me, if there are big chunks of mortar missing then that wall of many tonnes in weight is floating in mid air.You've gone from a couple of DIY able jobs to your house essentially falling down in a couple of posts (And with the amount you're seemingly willing to pay, then it'd probably be more cost effective to knock the house down and rebuild)
I want the job to be done decently. Slapping crap repointing over old pointing, and repainting the area to cover it up was a bodge done by the previous owner. Would you accept that on your house?
This means I need to get that paint off if possible. It would be better to do it first before the repointing gets done so I dont make a mess of the new pointing. Its very difficult to remove, Ive tried heat gun, chemical stripper. There are companies that offer high temperature steam cleaning (videos on youtube show it to be very quick and effective), I got a quote and it was £700+vat. Again, what am I supposed to do if that is what is being quoted? I cant magic a price of £200 out of thin air.
