- 19 Sep 2022
- Pyongyang
the rumors talk about 600watts and a 2-slot cooler, this is coming across as contradicting information
Think both could be true that the full chip usually used for the xx90/ti/titan could be a 600w monster but with AMD seemingly not bothering with halo products this gen Nvidia don't have to release that chip to us peasants and can keep it for Ai.the rumors talk about 600watts and a 2-slot cooler, this is coming across as contradicting information
Modded skyrim is truly epic and basically the closest you will get to actually feeling like you are in an open world fantasy realm. VR sickness is also a very individual thing. Some people suffer from it and others don't and often if you do get it then it improves over time. However I don't think SkyrimVR causes VR sickness any more than any other game. I am more prone to vertigo and I get that when jumping or falling off of great heights in video games.Does skyrim actually play well in VR? Any nausea? The video looks great and to be fair I'd not considered using VR in this way.
bottomline: the amount of guff that spews forth from your keyboard is truly astonishing.bottomline: its skyrim anyways, again casual content.. not so much in terms of engaging gameplay or storyline, doubt if VR is any kind of purchase driver for high end cards (the medium lacks any kind of respectable content), just the PC gamer ritual, once every 24 months - going to be the same this time around but only if nvidia feels obliged to launch the cards on time
The thing is we don't really know everything yet. We don't know if that's chip or board power use or tdp or what else that is. We don't know how much it really use in games either.I don't consider the extra power "needs" of the supposed leaked info that important, just like the 4090, the 5090 is going to be running typically in games at much lower draws anyway, and once an undervolt is applied, that will be around 150watts less maybe more? My 4090 draws less power than the 3080 Ti FE did typically.
I'm sitting here with a 4090 and an oculus quest and haven't even considered hooking it up to the PC!Modded skyrim is truly epic and basically the closest you will get to actually feeling like you are in an open world fantasy realm. VR sickness is also a very individual thing. Some people suffer from it and others don't and often if you do get it then it improves over time. However I don't think SkyrimVR causes VR sickness any more than any other game. I am more prone to vertigo and I get that when jumping or falling off of great heights in video games.
Also, what do you mean you 'hadn't considered using VR in this way'?
bottomline: the amount of guff that spews forth from your keyboard is truly astonishing.![]()
I just hope they don't make the 5090 smaller to save money on the heatsink because the best thing about the 4090 has been the over built coolers. In 23 months my Zotac Extreme Airo 4090 has never passed 70c and usually stays around 60c to 65c with a fan speed of 1000 to 1500rpm at 2830Mhz out of the box, even in my slightly airflow restricted Evolv X case.
Current cards are ridiculously massive but are so much quieter than they used to be because of it.
Not if it's 4ft long....the rumors talk about 600watts and a 2-slot cooler, this is coming across as contradicting information
Bet you don't miss that 2080Ti SLi setupIn 23 months my Zotac Extreme Airo 4090 has never passed 70c and usually stays around 60c to 65c with a fan speed of 1000 to 1500rpm at 2830Mhz out of the box, even in my slightly airflow restricted Evolv X case.
I do miss the look of two cards, but now a single GPU is getting almost as big and sucking down almost the same amount of power if they go with 600wBet you don't miss that 2080Ti SLi setup![]()
a skyrim player's ability to be astonished by anything is not a noteworthy observationbottomline: the amount of guff that spews forth from your keyboard is truly astonishing.![]()
hope its foldableNot if it's 4ft long....
We might end up with the smaller chips being named xx90 as that's where they perform in the stack and probably can be cooled with a 2 slot cooler.
Worse case scenario for consumer if that is the case
Yeah I've had a few graphics cards with coil whine/loud fans/both combined and they are insufferable. Especially the coil whine,my god that will drive you nuts.I returned 3 4090s and gave up. I’m not paying that much money for that noisy crap.
It's the humidity that makes it unbearable. I suffer the same crap every summer. My room is utterly insufferable.Air conditioner uses power to throw energy outside the flat. With it you pay double - once to burn by GPU and throw into the room then again to move it outside the flat. With 300W average in current games and 100W for CPU and then 100W for stuff like monitor etc. we have already space heater and in mild UK summer it's often unbearable, which stops me from gaming in a well insulated flat. Now imagine 600W card with all the other stuff and we have almost 1kW space heater in summer - my room would shoot up to 40C easily, I suspect (27C+ currently is normal with all windows open and 20C outside). There's no way I'd ever buy such GPU, no matter how fast, without installing aircon etc. first.
So you basically have both an RTX4090 and a VR headset and haven't discovered PCVR yet? LOL dude that is hilarious!I'm sitting here with a 4090 and an oculus quest and haven't even considered hooking it up to the PC!
The irony is that air conditioning systems are on average usually 3-4x more efficient than heating systems as they ONLY run on electricity and they are removing heat from the air which is easier than adding heat to the air. With global warming, AC units are only going to increase in usage time while heating decreases in usage time.It's the humidity that makes it unbearable. I suffer the same crap every summer. My room is utterly insufferable.
Nah, iirc these things takes months even after designs are done. I'd say CES with stock a few weeks/month after.Guess RTX 5080 and 5090 could launch at end of Sept or Oct or maybe at CES 2025.
Humidity is a bit tricky as it changes with temperature - warmer air can hold more water. So the hotter it gets the more it absorbs water even just from our bodies plus quicker evaporation - and so it gets humid fast. UK is a rather wet country, air can get humid fast indeed.It's the humidity that makes it unbearable. I suffer the same crap every summer. My room is utterly insufferable.
