- 13 Sep 2010
By which I mean... Have enough of an ATX mobo and don't wanna splash out on an ITX. Maybe next gen (or the one after that)
I could be tempted... But you can't do it on your own (unless you have 'assets' that you wouldn't want to allude to on the forums).... The issue is that I'm cheap - if my xspc raystorm (v3 I think) AM4 block will do, then I'm kinda tempted
. looks like another awesome build mate. Looking forward to your thoughts on the cpu block
Much like my ex, she looks much better from the back! Those struts are a lovely touch.
, needed that thanks man lol!Much like my ex, she looks much better from the back! Those struts are a lovely touch.
lol. They make it look like landing gear. Amazing.
Also like my ex, more girth round the back is better.
I do like the chunkier look with the springs, and also the struts aren't crossing over at the top now which was driving me mad but wasn't going to say anything
.By which I mean... Have enough of an ATX mobo and don't wanna splash out on an ITX. Maybe next gen (or the one after that)
it's been living in a beat up bitfenix shinobi with a £17 air cooler ever sinceI'm still stuck with which way I want to go tbh.... part of me wants to have everything in the one box (including big rads, some 2.5" and maybe a 3.5" drive.... maybe optical drive, although I can probably ditch that once I rip all my DVDs to the NAS...)
The other part of me wants to go a more modular route and wall or under-desk mount the rad(s)... wouldn't mind a small 7-9 or maybe 12" maxd extra screen for monitoring OBS/Discord, but again that could be a separate break out box (that might make more sense rather than looping an HDMI cable back in to the case, but had been considering DP alt mode from a motherboard USB-C header)
Edit: If I did go with the 480 under the desk or on the wall, I'd still probably want at least a 240 in the main case with a bypass and QDCs, so I could theoretically use it stand alone.... although this is yet another thing that I'll probably never need, except for maybe taking my PC to my parent's if I stay there to look after their dog again.... but even then I could either transplant it or build a secondary PC out of spares for that!
I think whatever happens, it'll take me a long time to decide and commit to an idea.... Even getting round to cleaning my watercooling stuff and Enthoo Primo has taken over 18 months so farit's been living in a beat up bitfenix shinobi with a £17 air cooler ever since
you're worse than me lol!I can't imagine open frame designs lend themselves to being portable7" is ideal, that's what i use currently though i've been tempted to mount my old 24" monitor back up to use as a stats display.
Blimey 18 months?!you're worse than me lol!
I like the idea of being able to keep the case as is with a radiator still mounted internally so it's not constantly tied to an external setup. That's why the manifold idea came to be but then the pc hasn't moved since so it's been kinda useless in that sense.
What about an external optical drive? Maybe a USB one, i remember having one of those awhile ago before i retired all physical media.
Yeah a USB optical drive is an option I could consider... the only other option is to stick with the cases I have as there aren't many with a slot for one now... I also have a 5.25" fan controller but again that's a problem with many possible solutions!
, instant portable lol.That’s awesome! I need it mounted to my sim rig above the pedalsSuspension mod complete! Got rid of the fake carbon fibre tubes in place for some real ones. Used a slightly thicker tube as well, 12mm compared to the previous 10mm, adds a tiny bit of girth but makes all the difference. The springs also have the benefit of holding the tube in a locked position and won't come loose.
Beautiful.
I realised I have over $200 in bitspower tokens. Stop giving me ideas![]()
