Well OCUK now doing price cuts on their 4000 Supers so I'm thinking we will be hearing news in the next month.
But........After looking am sure some the 4090 prices have gone up
You mean this company?EK confirmed next gen RTX 5080 and 5090 will launch soon this year in 2024.
20 Sept or Oct or maybe Nov?
i would be surprised to see them in quantities this side of Christmas if they do and you can be sure Nvidia will be charging top dollar for early adopters.![]()
EK hints at next-gen GPU launches this year - VideoCardz.com
EK Water Blocks preparing for ‘new GPU series announced for release later this year’ The company responds to recent media reports and confirms new cooling products for new GPUs are underway. There have been new reports about the departures of key employees from EK Water Blocks. The company has...videocardz.com
Their only purpose in life is to be milked lad otherwise they're uselessand you can be sure Nvidia will be charging top dollar for early adopters.![]()
It's the humidity that makes it unbearable. I suffer the same crap every summer. My room is utterly insufferable.
The irony is that air conditioning systems are on average usually 3-4x more efficient than heating systems as they ONLY run on electricity and they are removing heat from the air which is easier than adding heat to the air. With global warming, AC units are only going to increase in usage time while heating decreases in usage time.
My predictions
5090 = 65%-70% over 4090
Nothing that couldn't be beaten by throwing power and transistors at it. But then it will be expensive to buy and to run, likely much more than 4090.You're dreaming.
That's the same bump the 4090 was over the 3090 and that had a 50% reduction in process node with associated benefits to transistor count and clock speeds. The 5090 will have no such die shrink to lean on.
I said to my dad the humidity in England is ridiculous. It's literally tropical rainforest levels. I have an Alexa spy device in the kitchen,and it's like 'today expect highs of 22c' ok that's fine imo. Then it's like 'and the humidity will be 82 percent' ! Off topic sorry.This. I got up the other day and it was 20C in the house but 80% humidity and it was atrocious.
maybe the ac isnt properly sized for the room or its skipped a round of maintenance.. ac is supposed to drain excess water from the room, its actually integral to the cooling process, unless the fan is blowing over an open water reservoir because of a drainage blockThis. I got up the other day and it was 20C in the house but 80% humidity and it was atrocious.
In general terms - me neither. But in some specific use that they will blow out of proportion in marketing - perhaps.And I'm sure they'll try but I just can't see any way of obtaining a 60-70% performance bump on the same process node.
Which is why only really relative humidity matter. That said, most UK places have no Aircon nor dehumidifiers.also RH again is often misinterpreted - 80% RH at 20 deg C isnt comparable to 60% RH at 29. infact in absolute terms it could be the same quantity of water as the holding capacity of air increases with temperature
No chance for sept 20 I am afraidtheres some rumor abt a new node n3e.. for blackwell ofc
pls god make it sep 20
Dehumidifiers became really popular last Autumn after the death associated with mould went viral on the news. You couldn't find a good one in stock for a couple of months.Which is why only really relative humidity meter. That said, most UK places have no Aircon nor dehumidifiers.
