Will mull it over…
When it next rains, take the car to a quiet road nearby and try an emergency stop from 40 or 50mph, if they're half as bad as I expect them to be, that'll probably make your decision for you. Maybe they're an undiscovered gem and you'll be pulled to a quick and controlled stop but I suspect it's more likely your ABS will be working overtime and you'll be having a mild panic at just how much the car isn't stopping
