if this is your sort of thingOnly thing to remember is nothing is lost when dismantling, so feel free to keep breaking and rebuilding !I just went with the very first default selection because I've never actually played this beyond an hour. I know nothing about what you can build. I know nothing about well, anything because I just like to go in blind.
its the best way tbh Noxi.
you get to expirence it first hand with out the frustrations of stuff moving around.
enjoy your self, and loose hours of time to itif this is your sort of thing
I don't want to know the answer, but I'm going to assume there is a way for me to stop my bioreactor continually running even when I switch the smelter off because I'm not using it. I can't imagine for moment I'm supposed to run around flicking switches off to conserve power lol.
Only true for certain power sources, bioreactor is definitely on that list though.Been a while, but IIRC power generation only uses the resources needed to satisfy current demand anyway. You don't have to switch stuff off.
The animation definitely still plays regardless, but a quick test here confirms it's not using any fuel when nothing is drawing power.Hmmm odd. The smelter had nothing in the queue and yet the bar was still moving on the bioreactor. Plus the animation was loading still.
I shall check again tomorrow. It's going to be me of course.
If anything it's single player focused, multiplayer was added after community requests IIRC.is it good single player, or is it mostly online focused ?
Its good in both, its great in single player and its also great in co-op multiplayer (though I do wish that each player could build their own Hub)is it good single player, or is it mostly online focused ?
