- 2 Nov 2006
- Kent, UK
Hi Peeps
For the last few days my PC, which has been working fine, keeps restarting itself for no apparent reason. I would be working in my 3D app or After Effects and then it would make a faint blip noise and restart itself. I have re-installed the graphics driver but that had no effect. I have use Crystal Disk to check the hard drives and they are all fine. I have turned the machine on and just let it run and it sits happily and then reboots itself, sometime one after the other sometimes with an hour delay.
It is unerving. I am wondering whether it is the RAM playing up but normally that would fail at system boot? It's not the GPUs since I have two identrical ones and have switched them around and still get the same problem. So it kinda points to a Windows update possibly? I have noticed that when I used to boot up I would get a lock screen picture which I could like and then it would take me into the OS now it just has the same picture and no like/unlike button...
My system is a Threadripper 1920 with a Microstar X399 mobo, 32 gb RAM, two SSDs, four HDs and two RTX 28000ti GPUs and a 1600w PSU (so ample power) running Windows 10 Pro.
I am a bit clueless and any help would be greatly appreciated.
