Have your screwed the hinges directly into the front of the washing machine? I'd have assumed that would void any kind of warranty on them, then if it's just superficial?New Beko integrated washer dryer to replace the awful Hotpoint one I had before. Much bigger drum so should hopefully be a lot better at drying, and it seems much quieter too based purely on the self-cleaning cycle it's just finished doing.
I was thinking the vibrations is going to shake that door off or at least add noise.Have your screwed the hinges directly into the front of the washing machine? I'd have assumed that would void any kind of warranty on them, then if it's just superficial?
It's integrated, it's supposed to have the door attached!Have your screwed the hinges directly into the front of the washing machine? I'd have assumed that would void any kind of warranty on them, then if it's just superficial?
The old one got a bit rattly during a spin cycle but this one seems far better so far.I was thinking the vibrations is going to shake that door off or at least add noise.
I have to say, its been awesome on the cooks I have done so far, the extra height you get on the 3 series really helps. Theres loads of room to, I got 4 racks of baby backs on there , double indirect with the slow roller and the depth of flavour with the smoke was noticable over my Joe jnr.Man, I’d love that.
I had absolutely no idea that that was a thing, always just seen integrated being slimmer/shell-less and then either no cupboard door at all, or one attached to the cabinetry. Yours is a rather cool idea.It's integrated, it's supposed to have the door attached!
I've been looking at these myself, although at the moment I won't get through one song without stopping lol. (Running / jogging that is!![]()
One less charging cable to take on cycling holidays with me (these are now USB-C)
) i can do 45 to 60 mins on the x trainer but running causes my shins to flare up so taking it steady for now!Where from?It was ok, wouldn't buy again. Taste more like cola with ice cream
I got it from TescoWhere from?
Wall of fame! Ain't seen it for a while![]()
For your shins, have you tried some strong calf supports? It worked well for mine.i can do 45 to 60 mins on the x trainer but running causes my shins to flare up so taking it steady for now!
How do these sound or compare to your previous ones?
For your travels?Beryl AX
