If you're going with an X3D CPU then 6000 or 5600, 6000 C30 is considered optimal, but there's not a huge difference.
Non-X3D CPUs, I'd get the kits with tighter timings because the performance loss is a little higher, unless you're going with large capacity kits (32x2).
9000 CPUs might be able to push a bit higher on average, to 6200/6400, but I haven't seen enough comments to know that yet.
Unless there is something you absolutely need from an E board then you are throwing money at nothing.
I'd highly recommend looking at a B series board specced for your expansion requirements. The higher end boards all boil down to expansion in the main, not performance.
Thank you for chiming in everyone. in my vanity, I forked out for a Corsair Dominator Titanium DDR5 Lighting Enhancement Kit to pair with the genuine x2 32GB sticks for the rig I'm gradually building. So I was concerned for a moment. Cheers.
