- 5 Aug 2006
- Derbyshire
Hello all.
I am moving into a new build house in a couple of weeks and am looking for garage floor recommendations.
I'll be putting a workbench in there and two mx5s will be stored in there.
I also intend to work on there car in there, so I need flooring that won't mess up with ramps or axle stands.
There is a chance that someday I will have a little scissor lift in there, but that is just a thought right now.
History:
1) Had a sectional garage put in. I used concrete sealant on the floor as it was dusting then painted with good quality garage floor paint. Seemed pretty good but was only there a year before I moved.
2) 2018 new build with a single garage. I tried to replicate 1) but the paint just kept coming up. It could have been due to moisture coming up through the concrete.
3) 2024 new build with a double garage. Looking for ideas. I don't mind spending a few quid if the results are worth it.
History:
