yeah, it was the approach one i mostly struggled at. i have a golf adapter arriving on Saturday so will try again then
Let us know how the adapter works.
Not really sure where to post this Question
Is the Moss 1 & 2 Bundle worth buying for £21.99 (on Meta) ?
Edit:
I see it also on Steam for £20.51
Save 55% on Moss & Moss: Book II on Steam
store.steampowered.com
Does the steam version have better Graphics or is it the exactly same as the Meta version ?
The Steam version lets you play it on any hmd that can connect to Steam, now and in the future. The meta version limits you to their headsets only.
technically, you can run meta titles on meta and non meta headsets using steam and revive.
GitHub - LibreVR/Revive: Play Oculus-exclusive games on the HTC Vive or Valve Index, scroll down for downloads and installation instructions.
Play Oculus-exclusive games on the HTC Vive or Valve Index, scroll down for downloads and installation instructions. - LibreVR/Revivegithub.com
) It's also quite hard to swing correctly while only using one hand on the controller, and there is no room to put your second hand on there.Will be interested in your take on the golf adapter, and which one you purchased..
That Golf+ is something that I am needing to remove. I might have a play but it is a shared headset we are have and no one else would really play it. There isn't enough room to update it, failed to update to to that......just another chance for me to complain of the vanishing space on the 128GB headset..!
Being a shared headset then i guess it not cost that much to sell the 12GB headset and upgrade to the 512GB version now the price has dropped by about £150 and the cost of the upgrade will be shared
just tried it now. v happy with it in golf. hasn't made me any better but adds to the immersion. also I was a bit worried about it being a bit of a pain to remove the handle. but a quick game of eleven table tennis and Incan still use the controller normally. a tiny bit more weight but maybe ads to realism anyway. I think I will just keep them on all the time.
I have had a mad weekend and not had time to try it... however this is the one. initial thoughts are it will be perfect for what I need (kayaking and golf).
only niggle and it can't be helped is it is a bit of a faff adding and removing them from the handle when you don't need them. it would be nice if meta had designed the controllers with 3rd party extensions in mind so they could be easily hot swapped on and off. (I have the pro controllers which may be more faffy than the others)
for the money it's a great purchase.
yeah you do, you pull it through the grips and tie it to the shaft to stop it flying off...I think the only issue i'll have is.. I purchased my quest 3 second hand and it didn't come with the wrist straps, which I never used on my quest 2, so wasn't much of a big deal to me.. but it looks like you need the wrist strap to secure the controllers to the handle?
Windlands
Windlands on Meta Quest | Quest VR games | Meta Store
A first-person grappling hook exploration game. Soar through the ruins of a fallen civilization and discover the secrets of the ancient world.www.meta.com
try :
Enter the promo code WL90-0286C8 at checkout to get Windlands for just $1.49! Limited time only, codes limited to 100 uses.
approx £1.10
if you get one consider leaving a review at least.
This code has been redeemed too many times.
How strange, I've just tried it and it worked for me.Thanks for posting this
But i was not one of the lucky ones this time![]()
